Nexus 3172 upgrade firmware failed
slakos
switch# install all nxos bootflash:nxos.9.2.2.bin
Installer will perform compatibility check first. Please wait.
Installer is forced disruptive
Verifying image bootflash:/nxos.9.2.2.bin for boot variable "nxos".
[####################] 100% -- SUCCESS
Verifying image type.
Preparing "nxos" version info using image bootflash:/nxos.9.2.2.bin.
Preparing "bios" version info using image bootflash:/nxos.9.2.2.bin.
Collecting "running" plugin(s) information.
Collecting plugin(s) information from "new" image.
[####################] 100% -- SUCCESS               [####################] 100% -- SUCCESS
Performing module support checks.                    [####################] 100% -- SUCCESS
Notifying services about system upgrade.             [####################] 100% -- SUCCESS
Compatibility check is done:
Module  bootable          Impact  Install-type  Reason
     1       yes      disruptive         reset  default upgrade is not hitless
Images will be upgraded according to following table:
Module       Image                  Running-Version(pri:alt)           New-Version  Upg-Required
     1        nxos                               7.0(3)I7(9)                9.2(2)           yes
     1        bios                        v5.3.1(05/17/2019)    v5.2.0(05/18/2018)            no
Switch will be reloaded for disruptive upgrade.
Do you want to continue with the installation (y/n)?  [n] y
Install is in progress, please wait.
Performing runtime checks.                           [####################] 100% -- SUCCESS
Setting boot variables.
[###########         ]  50% -- FAIL.
Return code -1.
Install has failed. Return code 0x4093000C (Setting boot variables failed).
Please identify the cause of the failure, and try 'install all' again.
17 Replies 17
After restart I have below crash:
Press TAB in 1 seconds to list all boot options
Any other key to active boot...
Press  ctrl L to go to loader prompt in 2 secs
Booting kickstart image: bootflash:/nxos.9.3.7.bin
CardIndex = 11091
Image valid
MD5Sum mismatch
File does not exist, boot failed.
## get_boot_mode_from_bios,  ios_mode : 0, boot_mode : 0
Get to loader (ctrl+L) and boot from there the previous image installed (9.2.2). Once you are back to NXOS, verify if the image has the correct MD5 (show file <filename> md5)
Cheers,
Sergiu
crl+L is correct I can boot from another image
error was because bad compact in Nexus
I get new file from Cisco (n3100-compact.9.3.7.bin)
