Nexus 3548 upgrade firmware failed
vTaroko
When trying to upgrade firmware of N3K-C3548P-10GX, I bump into a problem as follows.
Would you please tell me how to solve this problem, thanks !!!
Setting boot variables.
[########### ] 50% -- FAIL.
Return code -1.
Install has failed. Return code 0x4093000C (Setting boot variables failed).
Please identify the cause of the failure, and try 'install all' again.
N3548# install all nxos bootflash:nxos.9.3.6.bin
Installer will perform compatibility check first. Please wait.
Installer is forced disruptive
Verifying image bootflash:/nxos.9.3.6.bin for boot variable "nxos".
[####################] 100% -- SUCCESS
Verifying image type.
Preparing "nxos" version info using image bootflash:/nxos.9.3.6.bin.
Preparing "bios" version info using image bootflash:/nxos.9.3.6.bin.
Collecting "running" plugin(s) information.
Collecting plugin(s) information from "new" image.
Performing module support checks.
Notifying services about system upgrade.
Compatibility check is done:
Module bootable Impact Install-type Reason
1 yes disruptive reset default upgrade is not hitless
Images will be upgraded according to following table:
Module Image Running-Version(pri:alt) New-Version Upg-Required
1 nxos 9.2(2) 9.3(6) yes
1 bios v5.4.1(03/30/2020) v5.4.1(03/30/2020) no
Switch will be reloaded for disruptive upgrade.
Do you want to continue with the installation (y/n)? [n] y
Install is in progress, please wait.
Performing runtime checks.
Return code -1.
Hello!
You must use a compact NX-OS image in order to upgrade a Nexus 3548 switch that does not have a model number ending in -XL. This is documented in the NX-OS 9.2(4) software release notes:
"Cisco Nexus 3548 and 3548-X platform switches must run a “compact” NX-OS software image due to limited bootflash space. This “compact” image can be created using the NX-OS Compact Image procedure; alternatively, a compact NX-OS software image can be downloaded directly from Cisco's Software Download website. This requirement does not apply to the Cisco Nexus 3548-XL switch."
A variant of NX-OS 9.2(4) that is pre-compacted for the Nexus 3548 platform can be found here. The filename you should download is n3500-compact.9.2.4.bin. A similar variant of NX-OS 9.3(6) that is pre-compacted for the Nexus 3548 platform can be found here (filename n3500-compact.9.3.6.bin).
Remember - you must upgrade to a compact image of NX-OS 9.2(4) before you upgrade to a compact image of NX-OS 9.3(6)!
I hope this helps - thank you!
-Christopher
6 Replies 6
Christopher Hart
Hello!
First and foremost, it looks like you're attempting to upgrade directly from NX-OS 9.2(2) to NX-OS 9.3(6) on a Nexus 3548. This upgrade path is not supported - an intermediary upgrade to NX-OS 9.2(4) is needed before you can upgrade to NX-OS 9.3(6). This is documented in the Cisco Nexus 3000 Series NX-OS Release Notes, Release 9.3(6) document:
"The following disruptive upgrade paths are supported for the non-XL platforms:
Release 6.0(2)A8(2) or later -> Release 6.0(2)A8(7b) or later -> Release 9.2(4) or later -> 9.3(6)"
However, I am not convinced that the root cause of this upgrade failure is the lack of this upgrade path. Can you confirm whether you are attempting to upgrade this switch using a compact image? This is described in detail in the "Compact Image for Cisco Nexus 3000, 3100, and 3500" section of the Cisco Nexus 3000 Series NX-OS Software Upgrade and Downgrade Guide, Release 9.2(x) document.
Thank you!
-Christopher
vTaroko
Hello Christopher,
Thanks for your kindly help.
First of all, I'm not using compact image to upgrade or downgrade N3K-C3548P-10GX
Refer to your instructions, I've tried to upgrade Nexus 3548 from NX-OS 9.2(2) to NX-OS 9.2(4) and downgrade from NX-OS 9.2(2) to NX-OS 9.2(1). The problem is the same. Would you please give me more suggestions to solve this problem, thanks !!!
Whether upgrade from NX-OS 9.2(2) to NX-OS 9.2(4) or downgrade from NX-OS 9.2(2) to NX-OS 9.2(1), the same error code as follows.
Return code -1.
Hello!
-Christopher
vTaroko
Hello Christopher,
At the first, thank you so much that my problem had been solved under your support.
According to NX-OS error message word for word, how can you come up with the correct solution about software image upgrade path and wrong image ?
After enter the “install” command, all check is 100% success.
Installer will perform compatible check first.
Compatible check is done.
Besides, ”Setting boot variables failed” it seems nothing to do with NX-OS image.
Return code -1.
Hello!
Excellent question! First and foremost, as a TAC engineer, I've personally observed this issue in a number of customer environments, and the "Setting boot variables failed" error message on a Nexus 3524 or 3548 switch is a key symptom of this particular issue.
Aside from that, if you manually set the boot variable of the Nexus switch (which is not a valid way to upgrade the software of Nexus switches, but is one of many crucial steps performed by the install all command, which is a valid way to upgrade the software of Nexus switches), the switch will return an error message that describes the issue. An example from my lab is shown here:
switch# configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
switch(config)# boot nxos bootflash:nxos.9.2.4.bin
ERROR: Image size too big. Use only the compact image on low memory N3k switches.
Failed to set the boot variable: Image size too big for low memory switch. Use compact image (0x40450038)
With that being said, you bring up a good point - you shouldn't have to be a TAC engineer to get meaningful feedback from the install all command regarding the fact that a compact image is required to upgrade the switch. I filed enhancement CSCvx18193 to improve the output of this command, which will hopefully prevent confusion in the future.
-Christopher
