Nexus 3548-X 40gig interface (4 x10gig) vs. port-channel
Marc.P
Hi - I have an environment that utilizes Nexus 3548-Xs. We have a need to increase our links between 3548s to 40gig. I've configured 40gig interfaces and know 40gig is supported. My question:
Is configuring 4 x 10gig to 1 single 40gig interface better than a 4 x10gig port-channel?
I'm looking for the best performance and no limitations on unicast or multicast traffic being sticky (to a single interface) and potentially microbursting over 10gig causing packet loss.
Marco
Hanfeng Cai
Everything has advantage and disadvantage.
Assume you're using port-channel, load-balance is per-flow, so it may got polarization or unbalanced flow by each link, but port-channel provide redundancy for links, which is function that single link can't provide.
Yes thanks and understood - this is what I meant about unicast and multicast being sticky per interface. Assume redundancy is in place. Assume we have min interfaces on our port-channel set to 4 (meaning port-channel will drop if 1 interface fails).
On a 40gig interface (non port-channel) the flows are not limited to a single interface so unicast or multicast performance or throughput is indeed better.
Is there any hit in latency or performance in any way with a non port-channel 40gig interface vs. a port-channel?
Thanks for you quick response!
Marc
From performance aspect, there is no difference at all.
