Nexus 3548-XL switch-mode
WinLing
I would like to confirm which switch mode is running on my Nexus 3548-XL. (N3K mode or N9K mode)
The result of the output is as follows, would you please tell me how to check it, thanks !!!
N3548XL# show system switch-mode
Switch mode configuration is not applicable for this platform.
That's because the NXOS image is unique to all 3 platforms: N3K, N3500, N9K.
Here are more details about the 9k-mode:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3000/sw/fundamentals/7x/b_Cisco_Nexus_3000_Series_NX-OS_Fundamentals_Configuration_Guide_7x/b_Cisco_Nexus_3000_Series_NX-OS_Fundamentals_Configuration_Guide_7x_chapter_011.html#task_5F0F1...
Also, you can see the difference of the commands here:
https://www.cisco.com/c/en/us/support/switches/nexus-3000-series-switches/products-command-reference-list.html
You will notice that only N3K has 3K mode and 9K mode:
Cisco Nexus 3000 Series NX-OS N3K Mode Command Reference (Configuration Commands), Release 9.3(1) 24/Sep/2019
Cisco Nexus 3000 Series NX-OS N3K Mode Command Reference (Show Commands), Release 9.3(1) 24/Sep/2019
Cisco Nexus 3000 Series NX-OS N9K Mode Command Reference (Configuration Commands), Release 9.3(1) 24/Sep/2019
Cisco Nexus 3000 Series NX-OS N9K Mode Command Reference (Show Commands), Release 9.3(1) 24/Sep/2019
Cheers,
Sergiu
Sergiu.Daniluk
What you are looking for is not available on Nexus 3500. This platform works in either warp mode (official name Algo Boost Engine which is the ultra low latency forwarding) or normal switching mode. You can use this command to see which mode is working.
switch# show hardware profile forwarding-mode
 forwarding-mode : warp
The 3K/9K mode is only applicable for Nexus 3000 or 3100 series.
Stay safe,
Sergiu
Hello Msdaniluk,
Thanks for your kindly reply.
According to Cisco download website of Nexus 3548-XL, there’re release notes for N3K and N9K.
Does these not mean N3K or N9K mode ?
All I know the difference between N3K and N9K mode is command line, am I right ?!
Thanks.
Cheers,
Sergiu
