Nexus 5596T hardware issue?
Hello all, i need some advise regarding an issue i experienced recently. above is a topology for my x4 5596T Nexus connected as per the diagram above and below are the VPC config and Port-channel config for the inter-connection.
today we experienced an issue where most servers which are connected to the 5K switches became unreachable, also internet connection which is connected via orphaned port on N5K-1 is also down. upon checking the 5K switches i noticed that Eth1/42 on N5K-1 is down, the status says Port is suspended. there are x4 FEX connected to N5K-1 & N5K-2 and FEX connections are online. attach is the logs for N5K-1 when the issue occurred. I can't seem to locate the cause of the issue. what i did to restore services is reboot N5K-1 switch. Could this be a hardware issue? it is the second time that this happened.
=========== N5K-1 ===========
vpc domain 1
peer-switch
role priority 8192
system-priority 8192
peer-keepalive destination 172.x.x.x
delay restore 150
peer-gateway
ip arp synchronize
interface port-channel1
description VPC peer link
switchport mode trunk
switchport trunk native vlan 499
switchport trunk allowed vlan 7,10,12,14-15,20,33,77,102,134-135,150,200-208,235-238,245-247,401-03,450,499,546,804,945
spanning-tree port type network
vpc peer-link
interface port-channel14
description to N5K-3&4 NEXUS
switchport trunk allowed vlan 7,10,15,77,102,134-135,150,200-207,238,245-247,401-403,450,499,804
vpc 14
interface Ethernet1/14
description Peer Link to N5K-2 1/14
switchport trunk allowed vlan 7,10,12,14-15,20,33,77,102,134-135,150,200-208,235-238,245-247,401-403,450,499,546,804,945
channel-group 1 mode active
interface Ethernet1/32
description Peer Link to N5K-2 1/32
interface Ethernet1/42
description to_N5K-3
channel-group 14 mode active
=========== N5K-2 ===========
vpc domain 1
peer-switch
role priority 16384
delay restore 150
peer-gateway
ip arp synchronize
vpc peer-link
vpc 14
description Peer Link to N5K-1 1/14
description Peer Link to N5K-1 1/32
description to N5K-4
=========== N5K-3 ===========
vpc domain 10
peer-switch
role priority 17000
delay restore 150
peer-gateway
ip arp synchronize
description VPC Peer Link
switchport trunk allowed vlan 7,10,15,77,102,134-135,150,200-208,235-239,245-247,307,401-403,450,499,546,804
vpc peer-link
description to N5K-1&2
01-403,450,499,804
vpc 14
interface Ethernet1/16
description Peer Link to N5K-4
interface Ethernet1/48
description N5K-1 Eth1/42
01-403,450,499,804
=========== N5K-4 ===========
vpc domain 10
peer-switch
role priority 17100
delay restore 150
peer-gateway
ip arp synchronize
description VPC Peer link
,804
vpc peer-link
vpc 14
description Peer Link to N5K-3
,804
,804
description N5K-2 Eth1/42
Sergiu.Daniluk
Hi @jethro.w.tambeana
It is important to know the reason why interface went into suspended state. Can you share the logs generated during the time of the issue from all 4 switches: show logging log
Cheers,
Sergiu
Hi there, please find attached logs. please note that clock on N5K-1 is behind by 1.5hr compared to other N5Ks. as mentioned, the issue was resolved by reloading N5K1 nexus. All N5K switches are running firmware version version 7.1(3)N1(1)
let me know if you need further information from my side.
