Nexus 7009 line card replacement
ervindm
We have A nexus 7009 switch that is just running as a single unit with just routing and only admin vdc and one prod vdc and  no vpc,fabric path etc on it . My question is can we replace the M2 and F2 line cards below with new F3 line cards as is into the same slot and will it just take that same line card config - (I suspect not but would like to confirm first )? Will that work or Does it need a particular process ? even a simple link to a cisco website explain this is all I need as it isn't clear on this ?
M2/F2 card
N7K-M224XP-23L
 N7K-F248XP-25E
F3 Card
N7K-F348XP-25
0 Replies 0
