I want to find a fixed switch with 100G ports supporting port channel (LACP).
In N9K interface config guide, the section "Guidelines and Limitations" shows:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/7-x/interfaces/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_7x/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_7x_chapter_0111....
*Port-channels are not supported on generation 1 100G line cards (N9K-X9408PC-CFP2) or generic expansion modules (N9K-M4PC-CFP2).
*Port-channels are supported on devices with generation 2 (and later) 100G interfaces. (7.0(3)I3(1) and later)
The module N9K-M4PC-CFP2 doesn't support port channel, so, Nexus 9300 is out.
There are three models in the Nexus 9200 with fixed 100G ports (N9K-C92160YC-X, N9K-C92304QC, N9K-C9236C),
Do these models support port channel and LACP in 100G ports?
BRs
