Nexus 9300-EX startup-config location
suporte2r
Hello dears,
Where is the startup-config file on Nexus 9300-EX switches series?
What is the default name file and the system directory used?
Thank you!
julian.bendix
Level 3
Level 3
Hi!
Should be "startup-config" in the file system "nvram:".
To see the full startup config including all defaults, this command should to the trick:
more nvram:startup-config
Let me now what you think.
Best regards
Julian
