Nexus 93180YC-EX ICAM recurring log entry
CVowles
In a secure environment, no internet access from the switch, just for context. Also unable to copy/paste anything from that environment onto a machine with internet access. With that out of the way..
NX-OS 9.3(7a)
Every 2 hours, I am seeing this log entry for one of our VLAN gateway SVI's on the switch.
2022-05-02 06:45:20 X.X.X.65 X.X.X.65 root May 2 13:45:20 X.X.X.65 : 2022 May 2 13:45:20 UTC: %AUTHPRIV-5-SYSTEM_MSG: root : TTY=unknown ; PWD=/var/sysmgr/work ; USER=root ; COMMAND=/isan/python/scripts/icam/icam_db_exec.py icam_entries_acl_age_sql /logflash/icamsql_1_1.db 1650289519 - sudo
Can't find any info regarding that message on the web, so here I am... hopefully I can get some traction on this as I have an auditor breathing down my neck but also want to help anyone else with the same issue.
I have tried the following:
Went into the bash shell hoping to find a cron job running this script every 2 hours... no cron jobs under root.
Tried the following commands to no avail, log entry is still occurring..
no icam monitor entries acl
no icam monitor interval
no icam monitor resource acl-tcam
no icam monitor system
Any assistance would be greatly appreciated. Cheers.
Sergiu.Daniluk
Hi @CVowles
This is from config guide:
Beginning with Cisco NX-OS Release 9.3(5), iCAM feature is always enabled and users cannot disable feature through no feature.
Ref: https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/93x/icam/b-cisco-nexus-9000-series-nx-os-icam-configuration-guide-93x/b-cisco-nexus-9000-series-nx-os-icam-configuration-guide-93x_chapter_010.html
I don't have a Nexus around to test, but there are two things I would test:
1. run "show run all | grep icam" and start doing "no" commands to everything.
2. if #1 doesn't solve the problem, I would change the logging level for authpriv to 3 or something to avoid the logs being generated.
Hope it helps,
Sergiu
Hi @Sergiu.Daniluk
Thanks for the advice. There is nothing in the running config with icam, but I did the "no" commands anyways thinking they might be hidden.
Also, I have the authpriv logging level set to 6 and cannot change it due to DISA STIG's... if I changed it that would make us out of compliance and would be a finding on our audits. Believe me though, that was one of my first thoughts haha
-Carson
I am having this issue now, was there a resolution?
Hi @stuart-duperron-ctr ,
Hope you are doing well.
I was reading this topic and here is what I can propose.
You can't stop the script execution but you can modify the frequency of this script execution every 24 hours instead of every 2 hours.
neuxs9000# configure
Enter configuration commands, one per line. End with CNTL/Z.
nexus9000(config)# icam monitor interval 24 history 168
Also, you can check on the device  the logging level. Default value is 3
nexus9000# show logging level | include authpriv
authpriv                3                       6
You can disable these messages by bringing "authpriv" logging level back to the default level 3 with the following CLI:
nexus9000(config)# logging level authpriv ?
  <0-7>  0-emerg;1-alert;2-crit;3-err;4-warn;5-notif;6-inform;7-debug
nexus9000(config)# logging level authpriv 3
Please, do not hesitate to mark this post as helpful if it helps you.
Have a nice day.
Kind Regards,
