Nexus-93180YC Sub Int
pri5605527206
Hi Folks,
In our data center design, We implemented a new VRF design to segregate the traffic and increase the capacity for specific traffic. So we have configured the 3 sub-interface. Ex Eth 1/49.234 Eth 1/50.234 Eth 1/52.234. We would like to know the counters for the sub-interface as to the below output for the physical interface.
  • #sh int eth 1/49 counter
    Port InOctets InUcastPkts
    Eth1/49 1984964821585 15921418838
    Port InMcastPkts InBcastPkts
    Eth1/49 466824 272
When I tried to see on sub inter counter, it shows o values even data is flowing.
  • sh int eth 1/52.456 counters
    Eth1/52.456 0 0
    Eth1/52.456 0 0
    Ethernet1/52.456 is up
    admin state is up, Dedicated Interface, [parent interface is Ethernet1/52]
    Hardware: 1000/10000/25000/40000/50000/100000 Ethernet, address: 3890.a5fa.cea1 (bia 3890.a5fa.ce
    de)
    Description: eBGP to or1-dccs02-4/31.456 sub-int
    Internet Address is 10.50.x.xxx/31
    MTU 9216 bytes, BW 100000000 Kbit, DLY 10 usec
    Encapsulation 802.1Q Virtual LAN, Vlan ID 456, medium is broadcast
    Auto-mdix is turned off
    EtherType is 0x8100.
Can someone help to understand this and if any resolution or if any config missing.
Thanks!
Rob Burchard
Hi @pri5605527206 ,
Per the config guide this is a limitation in the Nexus 9k platform, sub-interfaces do not have statistics support.
Limitations for Subinterfaces
The following are the limitations for subinterfaces:
  • Statistics for subinterfaces are not supported.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/7-x/interfaces/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_7x/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_7x_chapter_0101...
Hope this helps!
Rob
Thank you Rob!
