01-08-2020 10:42 AM
Hi Folks,
In our data center design, We implemented a new VRF design to segregate the traffic and increase the capacity for specific traffic. So we have configured the 3 sub-interface. Ex Eth 1/49.234 Eth 1/50.234 Eth 1/52.234. We would like to know the counters for the sub-interface as to the below output for the physical interface.
When I tried to see on sub inter counter, it shows o values even data is flowing.
Can someone help to understand this and if any resolution or if any config missing.
Thanks!
01-08-2020 07:24 PM
Hi @pri5605527206 ,
Per the config guide this is a limitation in the Nexus 9k platform, sub-interfaces do not have statistics support.
Limitations for Subinterfaces
The following are the limitations for subinterfaces:
Statistics for subinterfaces are not supported.
Hope this helps!
Rob
02-11-2020 03:40 PM
Thank you Rob!
