Nexus 93360YC-FX2 transceiver support
vnfmaqpfl1103
I would like to know if the N9K-C93360YC-FX2 supports the transceiver(SFP-10G-BX40D-I and SFP-10G-BX40U-I)
Cisco Optics Compatibility Matrix url says that it is not supported on the N9K-C93360YC-FX2.
But on the N9K-93180YC-FX, it is supported.
The difference between the N9K-C93360YC-FX2 and N9K-93180YC-FX Switch is a HW performance difference, and no other singularities are seen.
Is it really not supported the SFP-10G-BX40D-I and SFP-10G-BX40U-I on device N9K-C93360YC-FX2?
Thank you.
2 Accepted Solutions
balaji.bandi
if the document mentioned as not support there may be the reason it has no support.
since this is high-end equipment and investment bit reasonable compared to other models
contact local SE or cisco partner to confirm, since they may have tested as per your understanding.
BB
Christopher Hart
Hi Jin,
At the time of this writing, I can confirm that the Cisco Optics Compatibility Matrix is correct - the SFP-10G-BX40D-I and SFP-10G-BX40U-I transceivers are not supported on the Nexus 93360YC-FX2 platform. With respect to Nexus devices, these transceivers are supported on the following platforms:
  • N9K-C93180YC-EX
  • N9K-C93180YC-FX
  • N9K-C9372PX
  • N9K-C9372PX-E
  • N9K-C9396PX
  • N3K-C34180YC
  • N9K-X97160YC-EX line cards
  • N9K-X9564PX line cards
  • N9K-X9464PX line cards
If you require support for this transceiver, I highly recommend reaching out to your Cisco partner or account team to investigate whether support for this transceiver may be added on the -FX2 platform in the near future.
I hope this helps - Thank you!
-Christopher
balaji.bandi
BB
Christopher Hart
Hi Jin,
  • N9K-C93180YC-EX
  • N9K-C93180YC-FX
  • N9K-C9372PX
  • N9K-C9372PX-E
  • N9K-C9396PX
  • N3K-C34180YC
-Christopher
