Nexus 9348GC-FX3 ACI support?
John Cernac
Does the 9348GC-FX3 support ACI mode? I have not found any information that directly states is does or doesn't support ACI. CCW will only allow me to select NXOS mode and the data sheet for the FX3 family doesn't specify a minimum ACI software requirment.
Thanks in advance for the response.
John Cui
Hi John,
This model will be supported on ACI, but releases are TBD, so there's no official docs can be reference now.
If you find my reply solved your question or issue, kindly click the 'Accept as Solution' button and vote it as helpful.
You can also learn more about Cisco ACI through our live Ask the Experts (ATXs) session. Check out the ATXs Resources [https://community.cisco.com/t5/data-center-and-cloud-knowledge/cisco-aci-ask-the-experts-resources/ta-p/4394491] to view the latest schedule for upcoming sessions, as well as the useful references, e.g. online guides, FAQs.
