Nexus 'Buffer Boost' command
S891
Level 2
Level 2
I am working on Nexus 9500 series 40G line card 9432PQ. This card requires the port-channel be configured with 'no buffer boost' command - although the port capabilities shows that ports on this LC do not have 'buffer boost' feature enabled.
The problem I am observing is that as soon as port-channel is configured with 'no buffer boost' it causes issue with some applications. the packets start dropping and as a result the application suffers.
Anyone experienced this problem, anything could be applied as a fix?
0 Replies 0
