Nexus System Polcies __pfm_fanabsent_any_singlefan
Netmart
I was wondering where the system policies are managed, such as __pfm_fanabsent_any_singlefan
on platfrom Nexus7700 C7710:
It's not visible under system-policies:
1# sh event manager system-policy
Description : Action: none
Overridable : Yes
Overridable : Yes
Overridable : Yes
Overridable : Yes
Description : More than 30 link flaps in 420 seconds interval. Action: Error Disable the port
Overridable : Yes
Please advise.
2 Accepted Solutions
Sergiu.Daniluk
You do not see them because you are not in default VDC. Use the same command in the default vdc and you will see them all, including the __pfm_fanabsent_any_singlefan
N7K# show event manager system-policy | grep Name.*fan
Stay safe,
Sergiu
The "switchback" command in VDC X will only work when you actually use "switchto vdc X" command in the default VDC to switch to that VDC X. Otherwise will not do anything. To access the default VDC you can simply ssh to the it's mgmt IP.
Cheers,
Sergiu
Sergiu.Daniluk
Stay safe,
Sergiu
Thank you Sergiu.
I assume in order to switch to default VDC the following command has to be applied on Privilege Level:
1# sw?
switchback Switchback to default vdc
Cheers,
Sergiu
