09-25-2018 04:48 AM
Just looking for clarification on something I've noticed with a recent 5572UP installation I did.
I was replacing an existing older 5K pair of switches. vPC is configured on them in a standard way. I also enabled EIGRP in order to allow it to peer with an upstream 4507 core switch. When looking at the EIGRP neighbor table, I noticed that not only was the new 5K peering with the upstream switch, it was also peering with itself. Each of the SVIs found a peer across the vPC peer link. Is this normal? I don't think it would cause an issue but for some reason I found that surprising since HSRP is being used. Looking for confirmation that this is normal.
Solved! Go to Solution.
09-25-2018 05:53 AM - edited 09-25-2018 05:57 AM
Actually version doesn't really matters on Nexus 5K.
Your behaviour is the normal one and it is supported by VPC best practices:
https://www.cisco.com/c/en/us/support/docs/ip/ip-routing/118997-technote-nexus-00.html
--> Layer 3 and vPC Interactions: Supported Designs Fig.53
HTH,
ADP
09-25-2018 05:23 AM
Hello Nathan,
By saying "it was also peering with itself" do you actually mean it is peering with the other VPC peer? If not I don't really understand the topology, can you provide a quick diagram?
What version are you running on the new pair?
ADP
09-25-2018 05:31 AM
09-25-2018 05:46 AM
No worries, what NxOs version are you running on the pair?
09-25-2018 05:49 AM
HTH,
ADP
09-25-2018 05:55 AM
09-25-2018 05:59 AM
Link fixed, you should get to it now.
Cheers,
ADP
