Nexus9K NTP issue
n-86
Hi everyone,
I have a problem with NTP on our Nexus9k.
I have changed ntp configuration from:
ntp server 10.20.1.1 prefer use-vrf management
ntp server 10.20.1.2 use-vrf management
ntp source-interface mgmt0
to this:
ntp server 10.10.1.1 prefer use-vrf management
ntp server 10.10.1.2 use-vrf management
ntp logging
and after that i seeing that nexus switch not sync properly time with ntp servers(i'm not shure what mean 'polled in client mode' but i think it should be 'selected for sync'):
nexus02# show ntp peer-status
Total peers : 2
* - selected for sync, + -  peer mode(active),
- - peer mode(passive), = - polled in client mode
    remote                                 local                                   st   poll   reach delay   vrf
=10.10.1.1                              10.1.18.9                               2   64     377   0.04259management
=10.10.1.2                              10.1.18.9                               2   64     377   0.04260management
I can reach ntp servers using mgm0 interface as source:
nexus02# ping 10.10.1.1 source-interface mgmt0
PING 10.10.1.1 (10.10.1.1): 56 data bytes
64 bytes from 10.10.1.1: icmp_seq=0 ttl=253 time=42.777 ms
64 bytes from 10.10.1.1: icmp_seq=1 ttl=253 time=42.54 ms
64 bytes from 10.10.1.1: icmp_seq=2 ttl=253 time=42.735 ms
64 bytes from 10.10.1.1: icmp_seq=3 ttl=253 time=42.781 ms
64 bytes from 10.10.1.1: icmp_seq=4 ttl=253 time=42.668 ms
--- 10.10.1.1 ping statistics ---
5 packets transmitted, 5 packets received, 0.00% packet loss
round-trip min/avg/max = 42.54/42.7/42.781 ms
nexus02#
BIOS: version 05.33
NXOS: version 7.0(3)I7(6)
Maybe you know the reason of that behavior and will say me what i made incorrectly. Thank you in advance.
