Not able to ping the VM interface from Nexus 1000v
Balaji Murthy
Frequent Visitor
Frequent Visitor
Hi ,
Iam not able to ping one of the VM from the nexus 1000v, but the vethernet is showing UP, also mapped to correct VLAN. I had tried to disable & enable the interface ( Shut & no Shut ), but after doing also i was not able to ping the VM. In the Vcenter  everything is found OK, but once i migrate this VM to the other ESX host then i am able to ping the VM.This happens for the fourth time in the network on different VMs.
can any one help me on this ?
"Thanks in advance"
Robert Burns
Balaji,
1. What verison of 1000v are you running
2. What build of vSphere is the host(s).
3. Identify the veth # and VM "name".
Can you paste the following (or capture to a text file and attach to this thread):
-From the VSM - show run
-"                  "  - module vem x execute vemcmd show trunk (where x = VEM module #)
-"                   " - module vem x execute vemcmd show vlan
-"                   " - module vem x execute vemcmd show bd y (where x = VEM module #, and y = VLAN of the VM)
-"                   " - module vem x execute vemcmd show dr y (where x = VEM module #, and y = VLAN of the VM)
**Do the above 4 commands for the "working" and "non working" VEM host while the VM is running on it
Robert
