05-17-2019 03:18 PM
Good afternoon
I am looking for support on the topic "orphan-ports". In an environment with Nexus 7000 I have a vPC configured. This vPC is declared in two interfeces. However, with the "show vpc orphan-ports" command, both the vPC and the interfaces appear to me as orphan-ports in the up state.
What is the reason why I have this output ?....My configuration is the following:
Principal Secondary
interface port-channel5 interface port-channel5
description description
switchport access vlan 5 switchport access vlan 5
spanning-tree port type normal spanning-tree port-priority 128
mtu 9216 spanning-tree port type normal
mtu 9216
bandwidth 100000
interface Ethernet1/2 interface Ethernet1/2
channel-group 5 mode active mtu 9216
no shutdown bandwidth 10000000
no shutdown
interface Ethernet1/3 interface Ethernet1/3
the same as Ethernet1/2 the same as Ethernet1/2
#show vpc orphan-ports
VPC Role: Primary
VPC Peer-Link Status: Up
Interface Orphan Port Orphan-port
Suspend-config Status
Po5 - Up
Eth1/2 - Up
Eth1/3 - Up
You can support me by checking if I have an error or telling me how I can clean the "orphan-ports"
Solved! Go to Solution.
05-24-2019 08:38 PM
vPC <vPCnumber> command is missing under port-channel.
Example.
switch(config-if)# vpc 5
Kindly refer below link for better understanding of vPC configuration.
PS: Please don't forget to rate and mark as correct answer if this answered your question.
05-24-2019 08:38 PM
Example.
