OSPF Configuration Inquiry on Cisco vPC
qkrrudgh036
I'm planning to configure Double-Sided vPC and enable OSPF as shown in the attached diagram. I'd appreciate it if you could review my proposed configuration to ensure it's set up correctly.
For the vPC configuration, I've included the peer-gateway and layer3 peer-router commands.
Thank you.
Below is dual sided vPC
 what yoh config is PO between two vpc pairs and it work if yoh use under PO correct ""vpc"" value.
For ospf you will use vlan svi and that also good
You use peer-gateway and layer3 router and that excellent
So every thing from my view is OK
MHM
MHM
