05-11-2022 07:48 AM
Hi community,
On one of the Nexus 9k's with version 7.0(3)I7(5a) that I manage, logs have appeared in the system controller. Could you help me where to send the reviews?
2022 May 10 12:37:40 CH-N9K-CORE-K06-1B %$ VDC-1 %$ May 10 12:37:39 %KERN-0-SYSTEM_MSG: [97541465.351745] [1652204259] EMON: module 30 is not responding on EPC path. Reloading module. - kernel
2022 May 10 12:37:39 CH-N9K-CORE-K06-1B %$ VDC-1 %$ %PLATFORM-1-PFM_ALERT: Module 30 has experienced a kernel panic.
2022 May 10 12:37:40 CH-N9K-CORE-K06-1B %$ VDC-1 %$ %MODULE-2-MOD_DIAG_FAIL: Module 30 reported failure due to EPC heartbeat failure in device DEV_EPC_MAC (device error 0xcf51b137)
2022 May 10 12:40:07 CH-N9K-CORE-K06-1B %$ VDC-1 %$ %PLATFORM-2-MOD_DETECT: Module 30 detected Module-Type System Controller Model N9K-SC-A
2022 May 10 12:40:07 CH-N9K-CORE-K06-1B %$ VDC-1 %$ %PLATFORM-2-MOD_PWRUP: Module 30 powered up
[97541465.391738] Timer jitter detected on CPU1
[97541465.452961] EMON: CPU1 Seeing tx timer jitter 100 ms
[97541465.452967] EMON: CPU1 Seeing tx timer jitter 100 ms
[97541465.452971] Timer jitter recovered on CPU1
[97541623.796708] Timer jitter detected on CPU5
[97541623.875217] Timer jitter recovered on CPU5
[97541623.916724] Timer jitter detected on CPU5
[97541624.099797] Timer jitter recovered on CPU5
[97541626.136965] Timer jitter detected on CPU5
[97541626.450058] Timer jitter recovered on CPU5
[97541626.497003] Timer jitter detected on CPU5
[97541626.819406] Timer jitter recovered on CPU5
[97541627.740472] Timer jitter detected on CPU1
[97541627.781131] EMON: CPU1 Seeing tx timer jitter 80 ms
[97541627.781140] EMON: CPU1 Seeing tx timer jitter 80 ms
[97541627.781144] Timer jitter recovered on CPU1
[97541627.840481] Timer jitter detected on CPU1
[97541627.989380] EMON: CPU1 Seeing tx timer jitter 186 ms
[97541627.989388] EMON: CPU1 Seeing tx timer jitter 186 ms
[97541627.989391] Timer jitter recovered on CPU1
[97541628.518704] EMON: CPU1 Seeing tx timer jitter 30 ms
[97541628.518714] EMON: CPU1 Seeing tx timer jitter 30 ms
[97541628.560563] Timer jitter detected on CPU1
[97541628.645549] EMON: CPU1 Seeing tx timer jitter 106 ms
[97541628.645558] EMON: CPU1 Seeing tx timer jitter 106 ms
[97541628.645561] Timer jitter recovered on CPU1
Thank you.
Solved! Go to Solution.
05-12-2022 04:50 AM
yes i would advise to upgrade and test it. some time we do see re-appear bugs on other version too.
if you like to pursue (suggest to have a TAC call will help you).
05-11-2022 07:52 AM
05-11-2022 11:02 AM
Thanks for your answer Balaji,
I have some additional queries:
- The N9K has version 7.0(3)I7(5a) and in the affected releases it is not listed, does the bug also apply to version 7.0(3)I7(5a)?
- Do you consider it necessary to upgrade? If so, which one would you recommend?
05-12-2022 04:50 AM
