Private Vlan Trunking Questions
tckoon
I had read thru many documents about PVLAN. Some how there some questions I  need expert advice.
Especially the PVLAN trunking , also the what is common practise  interface type use for VMWARE ESXi host.
Please open attached powerpoint file, which consist of diagram and questions.
Kirk J
Might want to take a look at the white paper for UCS, PVlans, Vmware at https://www.cisco.com/c/en/us/support/docs/servers-unified-computing/ucs-hypervisors-operating-systems/201045-Private-VLAN-and-Cisco-UCS-Configuration.html which should cover most of your config questions.
Kirk..
Please mark correctly answered posts as Solved and Helpful, so others searching for same issue can more easily find the solution.
Kirk J
Kirk..
Appreciate your help to answer my question 1 , 2 & 3 in the slide.
