04-08-2010 02:30 AM
Hi!
I have a weird behavior on almost all of mine ESX hosts.
Vmotion don’t work between all hosts though they use the same port-profile in the nexus 1000 switch. Servers can ping each other when they are in the same ESX-host but they cannot ping the DG or servers in other ESX-hosts. On some ESX hosts this work fine but in others this doesn’t work at all. And the problem is not just the vmotion vlan, all other vlans seems to have the same problem.
Any help will be greatly appreciated.
I will attach the nexus config file.
Here is some show commands:
N1k-VSM-FortV# sh module
Mod Ports Module-Type Model Status
1 0 Virtual Supervisor Module Nexus1000V active *
2 0 Virtual Supervisor Module Nexus1000V ha-standby
3 248 Virtual Ethernet Module NA ok
4 248 Virtual Ethernet Module NA ok
5 248 Virtual Ethernet Module NA ok
6 248 Virtual Ethernet Module NA ok
7 248 Virtual Ethernet Module NA ok
8 248 Virtual Ethernet Module NA ok
9 248 Virtual Ethernet Module NA ok
10 248 Virtual Ethernet Module NA ok
11 248 Virtual Ethernet Module NA ok
12 248 Virtual Ethernet Module NA ok
13 248 Virtual Ethernet Module NA ok
14 248 Virtual Ethernet Module NA ok
15 248 Virtual Ethernet Module NA ok
16 248 Virtual Ethernet Module NA ok
17 248 Virtual Ethernet Module NA ok
18 248 Virtual Ethernet Module NA ok
19 248 Virtual Ethernet Module NA ok
20 248 Virtual Ethernet Module NA ok
21 248 Virtual Ethernet Module NA ok
22 248 Virtual Ethernet Module NA ok
23 248 Virtual Ethernet Module NA ok
Mod Sw Hw
1 4.0(4)SV1(2) 0.0
2 4.0(4)SV1(2) 0.0
3 4.0(4)SV1(2) 1.11
4 4.0(4)SV1(2) 1.11
5 4.0(4)SV1(2) 1.11
6 4.0(4)SV1(2) 1.11
7 4.0(4)SV1(2) 1.11
8 4.0(4)SV1(2) 1.11
9 4.0(4)SV1(2) 1.11
10 4.0(4)SV1(2) 1.9
11 4.0(4)SV1(2) 1.9
12 4.0(4)SV1(2) 1.9
13 4.0(4)SV1(2) 1.9
14 4.0(4)SV1(2) 1.9
15 4.0(4)SV1(2) 1.9
16 4.0(4)SV1(2) 1.9
17 4.0(4)SV1(2) 1.9
18 4.0(4)SV1(2) 1.9
19 4.0(4)SV1(2) 1.9
20 4.0(4)SV1(2) 1.9
21 4.0(4)SV1(2) 1.9
22 4.0(4)SV1(2) 1.9
23 4.0(4)SV1(2) 1.9
Mod MAC-Address(es) Serial-Num
1 00-19-07-6c-5a-a8 to 00-19-07-6c-62-a8 NA
2 00-19-07-6c-5a-a8 to 00-19-07-6c-62-a8 NA
3 02-00-0c-00-03-00 to 02-00-0c-00-03-80 NA
4 02-00-0c-00-04-00 to 02-00-0c-00-04-80 NA
5 02-00-0c-00-05-00 to 02-00-0c-00-05-80 NA
6 02-00-0c-00-06-00 to 02-00-0c-00-06-80 NA
7 02-00-0c-00-07-00 to 02-00-0c-00-07-80 NA
8 02-00-0c-00-08-00 to 02-00-0c-00-08-80 NA
9 02-00-0c-00-09-00 to 02-00-0c-00-09-80 NA
10 02-00-0c-00-0a-00 to 02-00-0c-00-0a-80 NA
11 02-00-0c-00-0b-00 to 02-00-0c-00-0b-80 NA
12 02-00-0c-00-0c-00 to 02-00-0c-00-0c-80 NA
13 02-00-0c-00-0d-00 to 02-00-0c-00-0d-80 NA
14 02-00-0c-00-0e-00 to 02-00-0c-00-0e-80 NA
15 02-00-0c-00-0f-00 to 02-00-0c-00-0f-80 NA
16 02-00-0c-00-10-00 to 02-00-0c-00-10-80 NA
17 02-00-0c-00-11-00 to 02-00-0c-00-11-80 NA
18 02-00-0c-00-12-00 to 02-00-0c-00-12-80 NA
19 02-00-0c-00-13-00 to 02-00-0c-00-13-80 NA
20 02-00-0c-00-14-00 to 02-00-0c-00-14-80 NA
21 02-00-0c-00-15-00 to 02-00-0c-00-15-80 NA
22 02-00-0c-00-16-00 to 02-00-0c-00-16-80 NA
23 02-00-0c-00-17-00 to 02-00-0c-00-17-80 NA
Mod Server-IP Server-UUID Server-Name
1 xxx.xx.x.21 NA NA
2 xxx.xx.x.21 NA NA
3 xxx.xx.x.131 35303933-3134-435a-4330-303134374650 al-esx101-prod.fortv.net
4 xxx.xx.x.132 35303933-3134-435a-4330-303134374753 al-esx102-prod.fortv.net
5 xxx.xx.x.133 35303933-3134-435a-4330-303134374750 al-esx103-prod.fortv.net
6 xxx.xx.x.134 35303933-3134-435a-4330-30313437484d al-esx104-prod.fortv.net
7 xxx.xx.x.135 35303933-3134-435a-4330-303134374738 al-esx105-prod.fortv.net
8 xxx.xx.x.136 35303933-3134-435a-4339-343838365232 al-esx106-prod.fortv.net
9 xxx.xx.x.137 35303933-3134-435a-4330-303134374848 al-esx107-prod.fortv.net
10 xxx.xx.x.138 35303933-3134-435a-4330-303134374851 al-esx108-vdi
11 xxx.xx.x.139 35303933-3134-435a-4330-30313437464c al-esx109-vdi
12 xxx.xx.x.140 35303933-3134-435a-4330-303134374838 al-esx110-vdi
13 xxx.xx.x.141 35303933-3134-435a-4330-30313437464b al-esx111-vdi
14 xxx.xx.x.142 35303933-3134-435a-4330-303134374835 al-esx112-vdi
15 xxx.xx.x.145 35303933-3134-435a-4330-30313437464e al-esx115-app
16 xxx.xx.x.146 35303933-3134-435a-4330-303134374830 al-esx116-app
17 xxx.xx.x.143 35303933-3134-435a-4330-303134374744 al-esx113-vdi
18 xxx.xx.x.144 35303933-3134-435a-4339-343838365230 al-esx114-vdi
19 xxx.xx.x.231 35303933-3134-435a-4330-30313437464a al-esx201-vdi
20 xxx.xx.x.232 35303933-3134-435a-4330-303134374746 al-esx202-vdi
21 xxx.xx.x.233 35303933-3134-435a-4330-30313437474e al-esx203-vdi
22 xxx.xx.x.239 35303933-3134-435a-4330-303134374837 al-esx209-app
23 xxx.xx.x.240 35303933-3134-435a-4330-303134374836 al-esx210-app
* this terminal session
N1k-VSM-FortV#
N1k-VSM-FortV# show svs neighbors
Active Domain ID: 5
AIPC Interface MAC: 0050-56a7-46fa
Inband Interface MAC: 0050-56a7-5a39
Src MAC Type Domain-id Node-id Last learnt (Sec. ago)
0050-56a7-30b8 VSM 5 0201 1123035.87
0002-3d40-0502 VEM 5 0302 165458.22
0002-3d40-0503 VEM 5 0402 155390.46
0002-3d40-0504 VEM 5 0502 154634.60
0002-3d40-0505 VEM 5 0602 153954.96
0002-3d40-0506 VEM 5 0702 71454.35
0002-3d40-0507 VEM 5 0802 152928.87
0002-3d40-0508 VEM 5 0902 152509.86
0002-3d40-0509 VEM 5 0a02 93198.45
0002-3d40-050a VEM 5 0b02 93032.88
0002-3d40-050b VEM 5 0c02 69893.90
0002-3d40-050c VEM 5 0d02 87083.88
0002-3d40-050d VEM 5 0e02 87332.18
0002-3d40-050e VEM 5 0f02 2284.95
0002-3d40-050f VEM 5 1002 1851.31
0002-3d40-0510 VEM 5 1102 87661.64
0002-3d40-0511 VEM 5 1202 87888.06
0002-3d40-0512 VEM 5 1302 165458.22
0002-3d40-0513 VEM 5 1402 165458.22
0002-3d40-0514 VEM 5 1502 162594.17
0002-3d40-0515 VEM 5 1602 1401.75
0002-3d40-0516 VEM 5 1702 940.90
N1k-VSM-FortV#
04-08-2010 03:39 AM
Bashir,
At first glance there's a few config issues:
On all your uplink port profiles you define a native VLAN, but you don't allow this VLAN on your uplink. All vlans including Native VLANs need to be allowed on the trunk. Also caution using Native VLANs. Using them allows for VLAN-mismatching easily. Ex. If you set a Native VLAN on the 1000v, and set a different VLAN on the upstream Switch, you'll potentially bridge VLANs and cause issues. Normally you should only be using ONE native VLAN, not multple - unless these are distinct networks.
As for not being able to even ping your default GW, ensure your IP subnet is correct on VLAN 1550. Can you ping the GW from a vSwitch if you migrate your SC and tag that port group with VLAN 1550?
port-profile type ethernet uplink-prod
description Uplink production
vmware port-group
switchport mode trunk
switchport trunk native vlan 3004
switchport trunk allowed vlan 100-102,200,203,300,710
channel-group auto mode on mac-pinning
no shutdown
state enabled
port-profile type ethernet uplink-pvs
description Uplink pvs
vmware port-group
switchport trunk native vlan 3003
switchport trunk allowed vlan 301
no shutdown
state enabled
port-profile type ethernet uplink-sc_vmotion
description Uplink for vmotion sc/mgmt control packet
vmware port-group
switchport trunk native vlan 3002
switchport trunk allowed vlan 202,1550,3040-3041
no shutdown
system vlan 1550,3040-3041
state enabled
Take a look at what I've pointed out. If that doesn't fix your issue pleaes provide the following:
1. Configuration of the upstream switchports your "uplink-sc_vmotion" interface connects to.
2. From one of the ESX host this is not working on, provide the output of "vemcmd show trunk", "vemcmd show port" and "vemcmd show vlan"
Robert
04-08-2010 05:41 AM
Robert: Why do I need the native vlans in the trunk, we use native vlan just because we don’t want the vlan1 to flow in the network. The native vlan have no other function in our case.
Yes I can ping the DGW and vlan 1550 is correct. I can also ping all the ESX hosts from the nexus 1000 switch.
Now the problem is a bit hard to explain but a example is like this:
From VEM(Module) 8 I can migrate a server to VEM(Module) 9. But it doesn’t work to migrate the same server to VEM(Module) 7. There seem to be a network failure.
If I instead of this way use the standard VMware switch (bypass the nexus 1000) it works just fine.
I will attach the port-config from both nexus 5000 switches.
here is the output of "vemcmd show trunk", "vemcmd show port" and "vemcmd show vlan" on the ESX host that this don’t work on and the same output from ESX that this works on.
Not Working ESX-HOST
N1k-VSM-FortV# module vem 7 execute vemcmd show trunk
Trunk port 16 native_vlan 3002 CBL 1
vlan(1) cbl 1, vlan(1550) cbl 4, vlan(3002) cbl 1, vlan(3040) cbl 4, vlan(3041) cbl 4,
Trunk port 17 native_vlan 3002 CBL 1
Trunk port 18 native_vlan 3004 CBL 1
vlan(1) cbl 1, vlan(102) cbl 4, vlan(203) cbl 4, vlan(300) cbl 4, vlan(3004) cbl 1,
Trunk port 19 native_vlan 3004 CBL 1
Trunk port 304 native_vlan 3004 CBL 1
Trunk port 305 native_vlan 3002 CBL 1
N1k-VSM-FortV# module vem 7 execute vemcmd show port
LTL IfIndex Vlan Bndl SG_ID Pinned_SGID Type Admin State CBL Mode Name
8 0 3969 0 32 32 VIRT UP UP 4 Access l20
9 0 3969 0 32 32 VIRT UP UP 4 Access l21
10 0 3040 0 32 0 VIRT UP UP 4 Access l22
11 0 3968 0 32 32 VIRT UP UP 4 Access l23
12 0 3041 0 32 1 VIRT UP UP 4 Access l24
13 0 1 0 32 32 VIRT UP UP 0 Access l25
14 0 3967 0 32 32 VIRT UP UP 4 Access l26
15 0 3967 0 32 32 VIRT UP UP 4 Access l27
16 1a060000 3002 T 305 0 32 PHYS UP UP 1 Trunk vmnic0
17 1a060100 3002 T 305 1 32 PHYS UP UP 1 Trunk vmnic1
18 1a060200 3004 T 304 2 32 PHYS UP UP 1 Trunk vmnic2
19 1a060300 3004 T 304 3 32 PHYS UP UP 1 Trunk vmnic3
48 1b060000 202 0 32 32 VIRT UP UP 4 Access vmk0
49 1b060010 1550 0 32 0 VIRT UP UP 4 Access vswif0
51 1b060030 1550 0 32 0 VIRT UP UP 4 Access IOMeterTest7 ethernet0
304 16000007 3004 T 0 32 32 VIRT UP UP 1 Trunk
305 16000008 3002 T 0 32 32 VIRT UP UP 1 Trunk
N1k-VSM-FortV# module vem 7 execute vemcmd show vlan
BD 1, vdc 1, vlan 1, 6 ports
Portlist:
16 vmnic0
17 vmnic1
18 vmnic2
19 vmnic3
304
305
BD 102, vdc 1, vlan 102, 3 ports
Portlist:
18 vmnic2
19 vmnic3
304
BD 202, vdc 1, vlan 202, 1 ports
Portlist:
48 vmk0
BD 203, vdc 1, vlan 203, 3 ports
Portlist:
18 vmnic2
19 vmnic3
304
BD 300, vdc 1, vlan 300, 3 ports
Portlist:
18 vmnic2
19 vmnic3
304
BD 301, vdc 1, vlan 301, 0 ports
Portlist:
BD 1550, vdc 1, vlan 1550, 5 ports
Portlist:
16 vmnic0
17 vmnic1
49 vswif0
51 IOMeterTest7 ethernet0
305
BD 1560, vdc 1, vlan 1560, 0 ports
Portlist:
BD 3002, vdc 1, vlan 3002, 3 ports
Portlist:
16 vmnic0
17 vmnic1
305
BD 3004, vdc 1, vlan 3004, 3 ports
Portlist:
18 vmnic2
19 vmnic3
304
BD 3005, vdc 1, vlan 3005, 0 ports
Portlist:
BD 3006, vdc 1, vlan 3006, 0 ports
Portlist:
BD 3040, vdc 1, vlan 3040, 4 ports
Portlist:
10 l22
16 vmnic0
17 vmnic1
305
BD 3041, vdc 1, vlan 3041, 4 ports
Portlist:
12 l24
16 vmnic0
17 vmnic1
305
BD 3967, vdc 1, vlan 3967, 2 ports
Portlist:
14 l26
15 l27
BD 3968, vdc 1, vlan 3968, 3 ports
Portlist:
1 inband
5 inband port security
11 l23
BD 3969, vdc 1, vlan 3969, 2 ports
Portlist:
8 l20
9 l21
N1k-VSM-FortV#
Working ESX - HOST
N1k-VSM-FortV# module vem 8 execute vemcmd show trunk
vlan(1) cbl 1, vlan(202) cbl 4, vlan(1550) cbl 4, vlan(3002) cbl 1, vlan(3040) cbl 4, vlan(3041) cbl 4,
N1k-VSM-FortV#
N1k-VSM-FortV# module vem 8 execute vemcmd show port
16 1a070000 3002 T 305 0 32 PHYS UP UP 1 Trunk vmnic0
17 1a070100 3002 T 305 1 32 PHYS UP UP 1 Trunk vmnic1
18 1a070200 3004 T 304 2 32 PHYS UP UP 1 Trunk vmnic2
19 1a070300 3004 T 304 3 32 PHYS UP UP 1 Trunk vmnic3
48 1b070000 202 0 32 1 VIRT UP UP 4 Access vmk0
49 1b070010 1550 0 32 1 VIRT UP UP 4 Access vswif0
50 1b070020 300 0 32 2 VIRT UP UP 4 Access Vmwi01 ethernet0
51 1b070030 300 0 32 3 VIRT UP UP 4 Access Vmwi03 ethernet0
52 1b070040 301 0 32 32 VIRT UP UP 4 Access Vmpvs02 ethernet0
53 1b070050 300 0 32 2 VIRT UP UP 4 Access Xenfil01 ethernet0
54 1b070060 300 0 32 3 VIRT UP UP 4 Access Vmddc02 ethernet0
304 16000009 3004 T 0 32 32 VIRT UP UP 1 Trunk
305 1600000a 3002 T 0 32 32 VIRT UP UP 1 Trunk
N1k-VSM-FortV#
N1k-VSM-FortV# module vem 8 execute vemcmd show vlan
Portlist:
16 vmnic0
17 vmnic1
18 vmnic2
19 vmnic3
304
305
Portlist:
18 vmnic2
19 vmnic3
304
BD 202, vdc 1, vlan 202, 4 ports
Portlist:
16 vmnic0
17 vmnic1
48 vmk0
305
Portlist:
18 vmnic2
19 vmnic3
304
BD 300, vdc 1, vlan 300, 7 ports
Portlist:
18 vmnic2
19 vmnic3
50 Vmwi01 ethernet0
51 Vmwi03 ethernet0
53 Xenfil01 ethernet0
54 Vmddc02 ethernet0
304
BD 301, vdc 1, vlan 301, 1 ports
Portlist:
52 Vmpvs02 ethernet0
BD 1550, vdc 1, vlan 1550, 4 ports
Portlist:
16 vmnic0
17 vmnic1
49 vswif0
305
Portlist:
Portlist:
16 vmnic0
17 vmnic1
305
Portlist:
18 vmnic2
19 vmnic3
304
Portlist:
Portlist:
Portlist:
10 l22
16 vmnic0
17 vmnic1
305
Portlist:
12 l24
16 vmnic0
17 vmnic1
305
Portlist:
14 l26
15 l27
Portlist:
1 inband
11 l23
Portlist:
8 l20
9 l21
N1k-VSM-FortV#
