On a nexus switch when i run the command "show int capability", it shows "Pvlan Trunk capable: no".
Does this mean the interface is not capable of being used as a trunk interface to carry Private VLAN tagged traffic.
I have two switches conencted to each other with private VLANs on both. I want a community interface on one switch to be able to get to the same community vlan on the other switch.
Ethernet1/30
Model: N9K-C93180YC-EX
Type (SFP capable): 10Gbase-(unknown)
Speed: 1000,10000,25000
Duplex: full
Trunk encap. type: 802.1Q
Channel: yes
Broadcast suppression: percentage(0-100)
Flowcontrol: rx-(off/on),tx-(off/on)
Rate mode: dedicated
Port mode: Routed,Switched
QOS scheduling: rx-(8q2t),tx-(7q)
CoS rewrite: yes
ToS rewrite: yes
SPAN: yes
UDLD: yes
MDIX: no
TDR capable: no
Link Debounce: yes
Link Debounce Time: yes
FEX Fabric: yes
dot1Q-tunnel mode: yes
Port Group Members: 117
EEE (efficient-eth): no
PFC capable: yes
Buffer Boost capable: no
Breakout capable: no
MACSEC capable: no
Any advice would be much appreciated.
Kind regards,
Javeed.
