07-08-2020 03:32 AM
I'm using the Programmability chapter of the Catalyst 4500 Series Switch Software Configuration Guide to PXE-boot a C4500X-32. I've successfully booted from a tftp image, and I successfully had a startup config file and a script downloaded. These are being stored here:
8 4096 Jul 07 2020 10:17:30.0000000000 +00:00 pxe/scripts
9 13 Jul 07 2020 10:17:30.0000000000 +00:00 pxe/scripts/hello2.script
10 4096 Jul 07 2020 10:17:30.0000000000 +00:00 pxe/ova
11 3112 Jul 07 2020 10:17:30.0000000000 +00:00 pxe/user-startup-config
12 4096 Jul 07 2020 10:17:30.0000000000 +00:00 scripts
13 13 Jul 07 2020 10:17:30.0000000000 +00:00 scripts/hello2.script
What are the next steps to make this zero-tough? How do I have the script executed? How do I copy the downloaded "user-startup-script" to the startup-config? And how do I get the booted image to the bootflash?
07-08-2020 05:28 PM
you need to understand the workflow for the zero-touch,
https://developer.cisco.com/docs/ios-xe/#!zero-touch-provisioning/dhcp-server-configuration-for-ztp
07-09-2020 06:06 AM
Thank you for the reply, however this ZTP mechanism requires Guest Shell which doesn't run on the 4500:
