Secondary VSM doesn't connect with Primary
naterevello
Environment: I'm currently using a dcloud lab for setting up a 1000v.  I want to build the implementation 'from the ground up' or as close to it as I can.
dCloud Lab Name: Cisco Nexus 1000V: Installing Cisco VSM and VEM for VMWare Lab v1.  The lab under the PEC is more of what I need, but it's closed for maintenance until 1/10/15.  dCloud labs seem out of date since they prefer the installer app and version 4.2.
After running through that lab a few times I've decided to install the newest version of N1kv ( System 5.2(1)SV3(1.5a) ).  I got the primary up and running.  I configured the port profiles.  I installed the VEM on the hosts, and migrated the hosts to the 1000v.
The trouble that I have run into is when I am setting up a secondary VSM for HA.  I'm not sure if it's the lab environment that's the limitation, or if it's a configuration error on my part.
I did enter 'system redundancy role primary/secondary' on the respective VSM's.  The secondary VSM didn't restart like it has in other Labs/environments.  The other environment/dcloud lab that I tried has the VSM already installed, the lab is just for creating/managing the port profiles.
Primary VSM show commands:
N1kv# sh version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_series_home.html
Copyright (c) 2002-2015, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
  kickstart: version 5.2(1)SV3(1.5a)
  system:    version 5.2(1)SV3(1.5a)
  kickstart image file is: bootflash:///n1000v-dk9-kickstart.5.2.1.SV3.1.5a.bin
  kickstart compile time:  8/15/2015 6:00:00 [08/15/2015 13:39:52]
  system image file is:    bootflash:///n1000v-dk9.5.2.1.SV3.1.5a.bin
  system compile time:     8/15/2015 6:00:00 [08/15/2015 15:22:16]
Hardware
  cisco Nexus 1000V Chassis ("Virtual Supervisor Module")
  Intel(R) Xeon(R) CPU E7- 283 with 4126584 kB of memory.
  Processor Board ID T5056813E21
  Device name: N1kv
  bootflash:    2332296 kB
System uptime is 0 days, 2 hours, 8 minutes, 30 seconds
Kernel uptime is 0 day(s), 2 hour(s), 9 minute(s), 7 second(s)
plugin
  Core Plugin, Ethernet Plugin, Virtualization Plugin
Reset reason
1) Time: Sat Aug 15 08:27:53 2015
Reason: Reset Requested by CLI command reload
N1kv# sh svs domain
SVS domain config:
  Domain id:    101
  Control vlan:  NA
  Packet vlan:   NA
  L2/L3 Control mode: L3
  Switch guid: cf16c21c-aa93-428f-b98d-b6dce279281e
  L3 control interface: mgmt0
  Status: Config push to Management Server successful.
  Control type multicast: No
  L3Sec Status: Enabled
Note: Control VLAN and Packet VLAN are not used in L3 mode
N1kv# sh svs connections
connection vcenter:
    ip address: 198.18.133.211
    remote port: 80
    protocol: vmware-vim https
    certificate: default
    datacenter name: dCloud-DC
    admin:
    max-ports: 8192
    DVS uuid: 33 4b 01 50 c4 35 a8 98-47 06 70 50 d9 c6 3f 9c
    config status: Enabled
    operational status: Connected
    sync status: Complete
    version: VMware vCenter Server 5.5.0 build-1312298
    vc-uuid: 67461318-8FFD-4EC1-8638-62D32F7285D7
    ssl-cert: self-signed or not authenticated
N1kv# sh module
Mod  Ports  Module-Type                       Model               Status
1    0      Virtual Supervisor Module         Nexus1000V          active *
3    1022   Virtual Ethernet Module           NA                  ok
4    1022   Virtual Ethernet Module           NA                  ok
Mod  Sw                  Hw
1    5.2(1)SV3(1.5a)     0.0
3    5.2(1)SV3(1.5a)     VMware ESXi 5.5.0 Releasebuild-1331820 (3.2)
4    5.2(1)SV3(1.5a)     VMware ESXi 5.5.0 Releasebuild-1331820 (3.2)
Mod  Server-IP        Server-UUID                           Server-Name
1    198.18.133.40    NA                                    NA
3    198.18.133.31    422025f7-043a-87f5-c403-5b9efdf66764  vesx1.dcloud.cisco.com
4    198.18.133.32    4220955f-2062-8e3e-04b8-0000831108e7  vesx2.dcloud.cisco.com
* this terminal session
N1kv# sh int virtual
Port        Adapter        Owner                    Mod Host
Veth1       vmk0           VMware VMkernel          3   vesx1.dcloud.cisco.com
Veth2       vmk4           VMware VMkernel          3   vesx1.dcloud.cisco.com
Veth3       Net Adapter 1  N1kv-VSM-P               3   vesx1.dcloud.cisco.com
Veth4       Net Adapter 2  N1kv-VSM-P               3   vesx1.dcloud.cisco.com
Veth5       Net Adapter 3  N1kv-VSM-P               3   vesx1.dcloud.cisco.com
Veth6       vmk0           VMware VMkernel          4   vesx2.dcloud.cisco.com
Veth7       vmk4           VMware VMkernel          4   vesx2.dcloud.cisco.com
Veth8       Net Adapter 1  N1kv-VSM-S               4   vesx2.dcloud.cisco.com
Veth9       Net Adapter 2  N1kv-VSM-S               4   vesx2.dcloud.cisco.com
Veth10      Net Adapter 3  N1kv-VSM-S               4   vesx2.dcloud.cisco.com
N1kv# sh running-config
!Command: show running-config
!Time: Tue Jan  5 20:44:53 2016
hostname N1kv
no feature telnet
username admin password 5 $1$e/9mVYDR$lpRLU0EPoY9AApRAG/h3P.  role network-admin
username admin keypair generate rsa
banner motd #Nexus 1000v Switch
ssh key rsa 2048
ip domain-lookup
ip host N1kv 198.18.133.40
errdisable recovery cause failed-port-state
vem 3
  host id 422025f7-043a-87f5-c403-5b9efdf66764
vem 4
  host id 4220955f-2062-8e3e-04b8-0000831108e7
snmp-server user admin network-admin auth md5 0xcab31b6c2edfee619396ff3266cc3970 priv 0xcab31b6c2edfee61
9396ff3266cc3970 localizedkey
rmon event 1 log trap public description FATAL(1) owner PMON@FATAL
rmon event 2 log trap public description CRITICAL(2) owner PMON@CRITICAL
rmon event 3 log trap public description ERROR(3) owner PMON@ERROR
rmon event 4 log trap public description WARNING(4) owner PMON@WARNING
rmon event 5 log trap public description INFORMATION(5) owner PMON@INFO
vrf context management
  ip route 0.0.0.0/0 198.18.128.1
vlan 1,10-12,111
vlan 10
  name Management-vMotion
vlan 11
  name Data-Network
vlan 12
  name NFS
vlan 111
  name PVLAN-Secondary
port-channel load-balance ethernet source-mac
port-profile default max-ports 32
port-profile type ethernet Unused_Or_Quarantine_Uplink
  shutdown
  description Port-group created for Nexus 1000V internal usage. Do not use.
  state enabled
  vmware port-group
port-profile type vethernet Unused_Or_Quarantine_Veth
  shutdown
  state enabled
  vmware port-group
port-profile type ethernet n1kv_mgmt-uplink
  switchport mode access
  switchport access vlan 10
  no shutdown
  system vlan 10
  state enabled
  vmware port-group
port-profile type ethernet nfs-uplink
  switchport access vlan 12
  no shutdown
  system vlan 12
  state enabled
  vmware port-group
port-profile type ethernet data-uplink
  switchport access vlan 11
  channel-group auto mode on mac-pinning
  no shutdown
  state enabled
  vmware port-group
port-profile type vethernet n1kv_mgmt_vlan
  no shutdown
  capability l3control
  system vlan 10
  state enabled
  vmware port-group
port-profile type vethernet nfs_vlan
  no shutdown
  system vlan 12
  state enabled
  vmware port-group
port-profile type vethernet vsm-control-packet
  no shutdown
  state enabled
  vmware port-group
port-profile type vethernet vsm-mgmt0
  no shutdown
  system vlan 10
  state enabled
  vmware port-group
port-profile type vethernet VM-Client
  no shutdown
  state enabled
  vmware port-group
interface port-channel1
  inherit port-profile data-uplink
  vem 3
interface port-channel2
  vem 4
interface mgmt0
  ip address 198.18.133.40/18
interface Vethernet1
  inherit port-profile n1kv_mgmt_vlan
  description VMware VMkernel, vmk0
  vmware dvport 32 dvswitch uuid "33 4b 01 50 c4 35 a8 98-47 06 70 50 d9 c6 3f 9c"
  vmware vm mac 0050.56A0.38BE
interface Vethernet2
  inherit port-profile nfs_vlan
  description VMware VMkernel, vmk4
  vmware dvport 64 dvswitch uuid "33 4b 01 50 c4 35 a8 98-47 06 70 50 d9 c6 3f 9c"
  vmware vm mac 0050.5660.64CA
interface Vethernet3
  inherit port-profile vsm-control-packet
  description N1kv-VSM-P, Network Adapter 1
  vmware dvport 96 dvswitch uuid "33 4b 01 50 c4 35 a8 98-47 06 70 50 d9 c6 3f 9c"
  vmware vm mac 0050.5681.636F
interface Vethernet4
  inherit port-profile vsm-mgmt0
  description N1kv-VSM-P, Network Adapter 2
  vmware dvport 128 dvswitch uuid "33 4b 01 50 c4 35 a8 98-47 06 70 50 d9 c6 3f 9c"
  vmware vm mac 0050.5681.3E21
interface Vethernet5
  description N1kv-VSM-P, Network Adapter 3
  vmware dvport 97 dvswitch uuid "33 4b 01 50 c4 35 a8 98-47 06 70 50 d9 c6 3f 9c"
  vmware vm mac 0050.5681.2411
interface Vethernet6
  vmware dvport 33 dvswitch uuid "33 4b 01 50 c4 35 a8 98-47 06 70 50 d9 c6 3f 9c"
  vmware vm mac 0050.566C.C9B4
interface Vethernet7
  vmware dvport 65 dvswitch uuid "33 4b 01 50 c4 35 a8 98-47 06 70 50 d9 c6 3f 9c"
  vmware vm mac 0050.5660.CA92
interface Vethernet8
  description N1kv-VSM-S, Network Adapter 1
  vmware dvport 98 dvswitch uuid "33 4b 01 50 c4 35 a8 98-47 06 70 50 d9 c6 3f 9c"
  vmware vm mac 0050.5681.326A
interface Vethernet9
  description N1kv-VSM-S, Network Adapter 2
  vmware dvport 129 dvswitch uuid "33 4b 01 50 c4 35 a8 98-47 06 70 50 d9 c6 3f 9c"
  vmware vm mac 0050.5681.DDB7
interface Vethernet10
  description N1kv-VSM-S, Network Adapter 3
  vmware dvport 99 dvswitch uuid "33 4b 01 50 c4 35 a8 98-47 06 70 50 d9 c6 3f 9c"
  vmware vm mac 0050.5681.B467
interface Ethernet3/1
  inherit port-profile n1kv_mgmt-uplink
interface Ethernet3/2
interface Ethernet3/3
interface Ethernet3/4
interface Ethernet3/5
  inherit port-profile nfs-uplink
interface Ethernet4/1
interface Ethernet4/2
interface Ethernet4/3
interface Ethernet4/4
interface Ethernet4/5
interface control0
line console
line vty
boot kickstart bootflash:/n1000v-dk9-kickstart.5.2.1.SV3.1.5a.bin sup-1
boot system bootflash:/n1000v-dk9.5.2.1.SV3.1.5a.bin sup-1
boot kickstart bootflash:/n1000v-dk9-kickstart.5.2.1.SV3.1.5a.bin sup-2
boot system bootflash:/n1000v-dk9.5.2.1.SV3.1.5a.bin sup-2
svs-domain
  domain id 101
  control vlan 1
  packet vlan 1
  svs mode L3 interface mgmt0
  switch-guid cf16c21c-aa93-428f-b98d-b6dce279281e
  enable l3sec
svs connection vcenter
  protocol vmware-vim
  remote ip address 198.18.133.211 port 80
  vmware dvs uuid "33 4b 01 50 c4 35 a8 98-47 06 70 50 d9 c6 3f 9c" datacenter-name dCloud-DC
  max-ports 12000
  connect
vservice global type vsg
  no tcp state-checks invalid-ack
  no tcp state-checks seq-past-window
  no tcp state-checks window-variation
  no bypass asa-traffic
  no l3-frag
vservice global
  idle-timeout
    tcp 30
    udp 4
    icmp 4
    layer-3 4
    layer-2 2
nsc-policy-agent
  registration-ip 0.0.0.0
  shared-secret **********
  log-level
N1kv# sh port-profile usage
port-channel1
port-channel2
Ethernet3/2
Ethernet3/3
Ethernet3/4
Ethernet4/2
Ethernet4/3
Ethernet4/4
Ethernet3/1
Ethernet4/1
Vethernet1
Vethernet6
Ethernet3/5
Ethernet4/5
Vethernet2
Vethernet7
port-profile Unused_Or_Quarantine_Uplink
port-profile Unused_Or_Quarantine_Veth
port-profile VM-Client
Vethernet3
Vethernet5
Vethernet8
Vethernet10
Vethernet4
Vethernet9
N1kv# sh system redundancy status
Redundancy role
      administrative:   primary
         operational:   primary
Redundancy mode
      administrative:   HA
         operational:   None
This supervisor (sup-1)
    Redundancy state:   Active
    Supervisor state:   Active
      Internal state:   Active with no standby
Other supervisor (sup-2)
    Redundancy state:   Not present
Peer Sup Mac Adddreses Learnt
   Control Interface:   00:50:56:81:06:14
      Mgmt Interface:   00:50:56:81:d1:ca
HA Packet Drops Due to Domain id Collision
   Control Interface:   11001
      Mgmt Interface:   2581
IMPORTANT NOTE: Please compare Peer Sup MAC addresses learnt above
with the actual Peer Sup's MAC addresses. If they are not same, execute
"peer-sup mac-addresses clear" on this VSM to form HA again
For the secondary VSM, I have to go through the console, so I can't copy/paste.  When I run the setup command and choose primary I get the following error (See attachment named: VSM secondary setup.PNG): SIOCSIFFLAGS: Permission denied  I have not found a solution for this error.
The secondary VSM reloads and then I'm back to a VSM that acts like it's isolated.  When I run sh module I get a public IP listed as the Server-IP.  This is what makes me think there's some sort of limitation with the gear.  This is also where I want another set of eyes, since maybe this solution is obvious to someone else with more experience.  See VSM secondary module.PNG for a screenshot.  I'm unable to ping the public IP for the secondary VSM.
I don't have access to the upstream switches.  The VSM's were installed by me via OVA deploy.
For a screenshot of the VM nic settings, see Vcenter VM Ints.PNG  Both the primary and secondary have the same settings.
Let me know if you need to see any other settings in Vcenter or need some more show commands.
Thanks!
naterevello
A follow-up questions is; How would I further troubleshoot, or verify, the connectivity?
James Clifford
Hi mate - in no particular order.....
  1. Does it work if you put them in Layer 2 mode?
  2. is port-profile type ethernet n1kv_mgmt-uplink  on VSM 2 in the same vlan?
  3. while in Layer 3 mode - can the all mgmt interfaces ping each other? including the vmware connection, gateway and VEMs?
  4. Try this: enter the command "system redundany role primary" on the primary vsm and "system redundancy role secondary" on the secondary then run setup again.
Is this a lab environment?
James
