SNMP configuration error on Nexus
Adnan Khan
Level 4
Level 4
When I am configuring SNMP on Nexus I am getting the below error.
localized auth key should start with 0x[Hex Digits]
snmp-server user <username> network-admin auth md5 <password> localizedkey.
Can anyone share the working SNMP v3 configuration for Nexus
Sergiu.Daniluk
Hi @Adnan Khan
When using the "localizedkey" option, as mentioned in the message, you need to be specifiy the passw in hex. Did you wrote it like that, in hex?
Cheers,
Sergiu
Assume if i give password as password. I checked without localizedkey as well.
Did you received an error without localizedkey? If yes, what was the error?
The error is the same with or without the "localizedkey" keyword.
For me this issue appears to have started after we upgraded to version 7.0(3)I7(8).
