ssh connection on nexus switches
cardosocristian
I'm trying to connect from my Rocky Linux 9.3 Linux server that uses OpenSSH version 8.7 on Nexus 9k switches that run the software version 7 and version 9.3
In version 7 I get the following error
Unable to negotiate with 192.168.160.10 port 22: no matching host key type found. Their offer: ssh-rsa
So I went to the .ssh/config file and put the lines
Host 192.168.160.10
HostkeyAlgorithms +ssh-rsa
That's what I found on internet forums without success.
In version 9 I get the following error
Bad server host key: Invalid key length
I already tried running the command "crypto key generate rsa modulus 2048" to see if the error changed and I was also unsuccessful.
Apparently Cisco switches have a very old version of OpenSSH or very old encryption
Has anyone experienced this and managed to get around it?
marce1000
 - You may also try to specify a (the) supported cipher(s) on the command line as in :
               ssh -o KexAlgorithms=diffie-hellman-group-exchange-sha256 ....
  (the above being an example)
 M.
