Switch Nexus 3064 Nxos
Hi Dear Friends
I have Nexus 3064-X
I used this version
nxos.7.0.3.I7.9.bin
Now i want Upgrade to version
n3000-compact.9.3.7.bin
My flash only 1.5G byte But used version Compact
Now my question Is what difference between version Compact and version standalone ???
i used bgp and layer3 feature For this switch can install  Version Compact ?
Christopher Hart
Hello!
The Nexus 3064 must use a compact image in order to run later NX-OS software releases due to its smaller bootflash size. This is described in detail in the "Background Information" section of the Nexus 3000, 3100, and 3500 NX-OS Compact Image Procedure document.
With respect to available features, there is no difference between a compact NX-OS image and a normal/full/non-compact NX-OS image. You will be able to run BGP and perform unicast routing with the compact NX-OS image without issue. The key difference between the two is in the size of the NX-OS image.
I hope this helps - thank you!
-Christopher
Christopher Hart
Hello!
-Christopher
