08-28-2018 04:59 AM
Hi folks,
I’d like to ask what am I actually getting when running nexus 3032Q in nexus9000 mode with “system switch-mode n9k” please?
Thank you?
adam
08-28-2018 05:43 PM
Hi Adam,
I don't think you can do the “system switch-mode n9k” on the 3032Q.
Snippet below
The Cisco Nexus 3100 Series switches, except Cisco Nexus 3100-V switches, now support two system modes: the N3K mode and the N9K mode. The N3K mode is the default mode. It uses the same CLI commands as the previous Cisco Nexus 3000 Series and Cisco Nexus 3100 Series NX-OS releases. The N9K mode enables the Cisco Nexus 3100 Series switches to use the Cisco Nexus 9000 Series switches CLI commands. Refer to the Cisco Nexus 9000 Series configuration guides for the Cisco Nexus 9000 Series CLI commands.
Note |
The N9K mode is available on the Cisco Nexus 3100 Series switches only and it is not available on the Cisco Nexus 3000 Series switches. Cisco Nexus 3100-V switches supports only N9K CLI. |
08-30-2018 01:28 AM
Sorry I messed up its 3132Q actually,
sh ver
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (C) 2002-2018, Cisco and/or its affiliates.
All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under their own
licenses, such as open source. This software is provided "as is," and unless
otherwise stated, there is no warranty, express or implied, including but not
limited to warranties of merchantability and fitness for a particular purpose.
Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or
GNU General Public License (GPL) version 3.0 or the GNU
Lesser General Public License (LGPL) Version 2.1 or
Lesser General Public License (LGPL) Version 2.0.
A copy of each such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://opensource.org/licenses/gpl-3.0.html and
http://www.opensource.org/licenses/lgpl-2.1.php and
http://www.gnu.org/licenses/old-licenses/library.txt.
Software
BIOS: version 4.4.0
NXOS: version 7.0(3)I7(3)
BIOS compile time: 11/06/2017
NXOS image file is: bootflash:///nxos.7.0.3.I7.3.bin
NXOS compile time: 2/12/2018 13:00:00 [02/12/2018 14:13:48]
Hardware
cisco Nexus3000 C3132Q Chassis
Intel(R) Core(TM) i3- CPU @ 2.00GHz with 4031400 kB of memory.
Processor Board ID FOC19040PEF
Device name: nyc.dc1.sw1.n3132Q
bootflash: 1880320 kB
usb1: 0 kB (expansion flash)
Kernel uptime is 6 day(s), 0 hour(s), 36 minute(s), 49 second(s)
Last reset at 510684 usecs after Fri Aug 24 03:39:34 2018
Reason: Reset due to upgrade
System version: 7.0(3)I4(5)
Service:
plugin
Core Plugin, Ethernet Plugin
Active Package(s):
show module
Mod Ports Module-Type Model Status
1 32 32x40G Supervisor N3K-C3132Q-40GE active *
Mod Sw Hw Slot
1 7.0(3)I7(3) 1.2 NA
Mod MAC-Address(es) Serial-Num
1 74-a0-2f-c6-e3-08 to 74-a0-2f-c6-e3-6f FOC19040PEF
Mod Online Diag Status
1 Pass
* this terminal session
08-30-2018 10:31 AM
With the N3k operating in the N9k mode you have bit more flexibility to configure CoPP. The TCAM carving is also different. There is also differences in the QoS implementation.
There may also be a license piece that may come into play when using n9k mode so be aware of that as well.
snippet
The Cisco Nexus 3164Q, 31128PQ, 3232C, and 3264Q switches and the Cisco Nexus 3100 Series switches in N9K mode run Cisco Nexus 9000 Series software and follow the Cisco Nexus 9000 license model. Therefore, these switches require the Layer 3 Enterprise Services Package (rather than the Layer 3 Base Services Package) to support routing protocols.
Hope this help.
-Raj
