QoS implementation problem on N9Ks
aok
Hello
We attempted to enable QoS on our edge Nexus 9k pair for a couple of public facing URLs as follows:
!! define qos policy-map
policy-map type qos classify
  class CC-servers
     set qos-group 1
  class class-default
!! define queuing policy-map
policy-map type queuing shape-out
  class type queuing c-out-q3
     bandwidth remaining percent 0
  class type queuing c-out-q2
  class type queuing c-out-q1
     bandwidth percent 5
  class type queuing c-out-q-default
     bandwidth remaining percent 95
!! classify public-facing URLs
ip access-list CC-traffic
  10 permit ip <public IP>/32 any
  20 permit ip <public IP>/32 any
class-map type qos match-any CC-servers
  match access-group name CC-traffic
!! mark traffic coming in on internal interfaces
int po101
  service-policy type qos input classify
!! apply queuing to outbound interface
int eth1/48
  service-policy type queuing output shape-out
After applying the service-policies and repeatedly browsing to the URL in the class-map we were not seeing any matches in QoS-group 1. We were also seeing the QoS-group 0 queue depth increasing and dropping OOBFC Unicast packets:
N9K# show queuing interface eth1/48
slot 1
Egress Queuing for Ethernet1/48 [Interface]
QoS-Group# Bandwidth% PrioLevel Shape QLimit
Min Max Units
3 0 - - - - 6(D)
2 0 - - - - 6(D)
1 5 - - - - 6(D)
0 90 - - - - 6(D)
| QOS GROUP 0 |
| | Unicast | OOBFC Unicast | Multicast |
| Tx Pkts | 902062723| 6258002562738| 20039|
| Tx Byts | 137642248077|1368124095302192| 1305112|
| Dropped Pkts | 0| 67| 0|
| Dropped Byts | 0| 11572| 0|
| Q Depth Byts | 0| 832| 0|
| QOS GROUP 1 |
| Tx Pkts | 0| 0| 0|
| Tx Byts | 0| 0| 0|
| Dropped Pkts | 0| 0| 0|
| Dropped Byts | 0| 0| 0|
| Q Depth Byts | 0| 0| 0|
| QOS GROUP 2 |
| Tx Pkts | 0| 0| 0|
| Tx Byts | 0| 0| 0|
| QOS GROUP 3 |
| Tx Pkts | 0| 0| 0|
| Tx Byts | 0| 0| 0|
| CONTROL QOS GROUP |
| Tx Pkts | 26824599| 0| 92058763|
| Tx Byts | 2608340064| 0| 10197133246|
| SPAN QOS GROUP |
| Tx Pkts | 0| 0| 0|
| Tx Byts | 0| 0| 0|
Any idea what the issue might be? We removed the policies from the interfaces for now until we figure out what's wrong.
AO
6 Replies 6
Rajeshkumar Gatti
If you can paste "show run ipqos" sanitized for the public forum along with information of whether the ports are L3 or L2.
Also which 9k model and version are you using?
if I have to guess then likely a TCAM carving is needed but can't tell with the limited config pasted here.
-Raj
Removing this entry as I was logged in with my old account. Re-posted under akomili
Hi Raj
Here is the current output (it's the same on both N9Ks), bearing in mind we removed the marking and queuing from the interfaces because it wasn't working properly:
N9K# sh run ipqos
!Command: show running-config ipqos
!Time: Thu Aug 23 17:31:07 2018
version 7.0(3)I2(3)
  class CC-servers
    set qos-group 1
  class class-default
    bandwidth percent 5
N9K# sh ip access-lists CC-traffic
IP access list CC-traffic
We were marking the traffic on a port-channel as follows:
int po101
And queuing the traffic on a physical interface outbound:
int eth1/48
Here is the config for those L2 interfaces, along with some other show command output:
N9K# sh run int po101
interface port-channel101
  description VPC to Rack 1 5524s
  switchport mode trunk
  vpc 101
N9K# sh run int ethernet 1/48
interface Ethernet1/48
  description Internet
  switchport access vlan 504
  spanning-tree port type edge
N9K# sh port-channel summary interface port-channel 101
Group Port- Type Protocol Member Ports
Channel
101 Po101(SU) Eth LACP Eth1/31(P) Eth1/32(P)
N9K# sh run int eth1/31
interface Ethernet1/31
  channel-group 101 mode active
N9K# sh run int eth1/32
interface Ethernet1/32
interface Vlan504
  description ISP Transit
  no shutdown
  ip access-group VLAN504_in in
  vrf member ISPtoDMZ
  no ip redirects
  ip address <public IP>/29
  hsrp version 2
  hsrp 504
  authentication md5 key-string 504
  preempt delay minimum 30
  priority 150
  timers 1 3
  ip <public IP>
N9K# sh run vrf ISPtoDMZ
interface Vlan502
  vrf member ISPtoDMZ
interface Vlan504
  vrf member ISPtoDMZ
vrf context ISPtoDMZ
  description ISP to DMZ Sonicwall Bypass
  ip route 0.0.0.0/0 <public IP>
  ip route <public range>/24 <public IP>
The N9K version is C9396PX running 7.0(3)I2(3). Let me know if you need more info.
Thanks for your help
AO
Sorry I missed following up on this thread. I tested on a later release 7.0(3)I4(7) and this seems to work.
I generally avoid suggesting an upgrade as a solution but sometimes I have found that customer are more open to that idea if it can solve issues quickly. If you want to tread that path then use this link on the recommended release.
Meantime I will try to test this on your existing release and revert back.
-Raj
Hi Raj
Thank you, that would be so helpful if you could test on our current release! From the link it looks like we should be upgrading anyway as we are a few releases behind. I'll work on putting a plan together for that but yes in the meantime it would be great to know if the QoS issue is related.
AO
Works for me in 7.0(3)I2(3). I would open a TAC case to deep dive.
//NXOS: version 7.0(3)I2(3)
  10 permit ip 10.1.1.1/32 any
version 7.0(3)I2(3)
  class CC-servers
    set qos-group 1
  class class-default
    bandwidth percent 5
interface Vlan500  >>> incoming
  no shutdown
  ip address 10.1.1.2/24
interface Vlan504  >>> outgoing
  no shutdown
  ip address 10.1.4.2/24
// Outputs
9396_A# sh policy-map int e1/1
Global statistics status :   enabled
Ethernet1/1
  Service-policy (qos) input:   classify
    SNMP Policy Index:  285213622
    Class-map (qos):   CC-servers (match-any)
     Slot 1
        270 packets   >>>>>>>>>>>>>>>>>>>>
     Aggregate forwarded :
        270 packets
      Match: access-group CC-traffic
      set qos-group 1
    Class-map (qos):   class-default (match-any)
     Slot 1
        612 packets
        612 packets
  Service-policy (queuing) output:   default-out-policy
    Class-map (queuing):   c-out-q3 (match-any)
      priority level 1
      queue dropped pkts : 0
      queue depth in bytes : 0
    Class-map (queuing):   c-out-q2 (match-any)
    Class-map (queuing):   c-out-q1 (match-any)
    Class-map (queuing):   c-out-q-default (match-any)
      bandwidth remaining percent 100
// Queueing
9396_A# sh queuing interface e1/3
slot  1
Egress Queuing for Ethernet1/3 [Interface]
                                   Min          Max        Units
      3             0         -           -            -     -            6(D)
      2             0         -           -            -     -            6(D)
      1             5         -           -            -     -            6(D)
      0            90         -           -            -     -            6(D)
|                              QOS GROUP 0                          |
|                |  Unicast       | OOBFC Unicast  |  Multicast     |
|        Tx Pkts |               0|               0|               0|
|        Tx Byts |               0|               0|               0|
|                              QOS GROUP 1                          |
|        Tx Pkts |               0|             200|               0|  >>>>>>>>>>>>>>>>
|        Tx Byts |               0|           20400|               0|
|                              QOS GROUP 2                          |
|        Tx Pkts |               0|               0|               0|
|        Tx Byts |               0|               0|               0|
|                              QOS GROUP 3                          |
|        Tx Pkts |               0|               0|               0|
|        Tx Byts |               0|               0|               0|
|                      CONTROL QOS GROUP                            |
|        Tx Pkts |             810|               0|               2|
|        Tx Byts |           57248|               0|             128|
|                         SPAN QOS GROUP                            |
|        Tx Pkts |               0|               0|               0|
|        Tx Byts |               0|               0|               0|
Port Egress Statistics
