TCP-DUMP
Ratheesh mv
I have run TCP dump on N9K-C9348GC-FXP and saved as pcap file. I am able to read the pcap file in the text(CLI) format but not able to find the file where it has saved in the box .My requirement is I need to move the pcap file to the external server form the nexus box .
If I use this command "tcpdump -r Core_BGP.pcap I can read the pcap file but I need to move the file to the external server.
Thanks in advance..
Sergiu.Daniluk
Hi @Ratheesh mv
You can capy the file from the switch using SCP. If you are using windows, you can use WinSCP client.
For ACI, make sure you change the shell to bash:
For NXOS, have a look at this excellent post: https://community.cisco.com/t5/data-center-documents/getting-winscp-on-n9k-to-work-settings-config-required/ta-p/3818490
Stay safe,
Sergiu
