THRESHOLD_EXCEEDED_WARN: Utilization of 93 percent OSPF LSA
Madhu
Problem Statement :
We get notified of these logs from the Core switch
2024 Jun 23 20:07:55.084 DCCore-1-N9K %ICAM-4-SCALE_THRESHOLD_EXCEEDED_WARN: Utilization of 93 percent for feature OSPF LSAs is over the warning threshold.
2024 Jun 23 22:07:58.794 DCCore-1-N9K %ICAM-4-SCALE_THRESHOLD_EXCEEDED_WARN: Utilization of 93 percent for feature OSPF LSAs is over the warning threshold.
2024 Jun 24 00:08:01.277 DCCore-1-N9K %ICAM-4-SCALE_THRESHOLD_EXCEEDED_WARN: Utilization of 93 percent for feature OSPF LSAs is over the warning threshold.
Further checking, Switch has limitation of 100000 on Nexus 9500 and currently we are utilizing full.
(VDC:1,TAG:700)         -         -         1   0.09   0.00   0.09   2024-06-11 12:31:37   0.09   2022-08-20 09:16:53
                OSPF LSAs    100000    100000     85330  85.33 101.15  92.20   2024-06-18 18:35:23 117.68   2023-09-14 23:07:41
          (VDC:1,TAG:100)         -         -     75372  75.37  88.71  81.41   2024-06-18 18:35:23 106.74   2023-09-14 23:07:40
As per the screenshot, the OSPF process ID 100 is consuming more than 88% ..
Technically, the Type 5 LSA is consuming more routes in the database.  Please find the attached type 5 SLA routes.
Process 100 database summary
LSA Type Count
Opaque Link 0
Router 36
Network 18
Summary Network 10539
Summary ASBR 289
Type-7 AS External 0
Opaque Area 0
Type-5 AS External 64481
Opaque AS 0
Non-self 70753
Total 75363
We have identified external routes being redistributed into OSPF, causing increased database utilization.
Upon inspection of several Type-5 routes, we found that they are learned from various locations.
Summarizing these routes is complex, as we lack visibility into which routes are actively used by location teams.
We have DC and DR setup across all the locations. Summarization is bit hard.. We may encounter an outage.
Note:
All these segments are learned from other locations. Each segment is also different in each location, hence summarizing these routes is a bit complex in origin ABR/ASBR
Please provide a possible alternate solution instead of summarization. Thank you…
5 Replies 5
marce1000
          - FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwh43960
                    You may want to investigate further using these commands :
                       show hardware internal forwarding table utilization
                          show icam scale
                          show icam resource fib-tcam mod 1 inst 0
 M.
Madhu
Thank you for the response.
I have verified the the below command output and got identified OSPF process id 100 causing the database utilization.
#show icam scale utilization
I have attached the logs, could you please review and confirm with me does it affect by bug (or) any alternate solution available instead of route summarization.
Note: All these segments are learned from other locations. Each segment is also different in each location, hence summarizing these routes is a bit complex in origin ABR/ASBR
  - I do not have enough expertise to comment on those outputs  ; best is to always use the latest advisory software version for the involved platforms. You will need TAC support  I think , to get further solutions (if needed)
 M.
Madhu
FYI , Tac suggested to do the route summarization
Tx for the info,
M.
