UADP High Temperature
BornJames
Hello Team,
We are having an issue with one of the chassis.
C9407R
when I run show environment I can see that
Slot    SENSOR             Current State     Reeding           Threshold(Minor,Major,Critical,Shutdown)
R0   Temp:Coretemp        Normal          69  Celsius       (107,117,123,125) (Celsius)
R0   Temp:UADP               Minor           107  Celsius       (107,117,123,125) (Celsius)
The room Temperature is lower the the other chassis and the other chassis temp for the same sensor is 53 Celsius and core 47
All the fans are working fine
I am wondering if anyone knows what would be the issue?
BornJames
dust blocking airflow
f00z
Level 3
Level 3
Need to make sure there are no holes in the chassis.. I.e. make sure every slot has a blank filler plate that is appropriate for the slot, even the power supply and sup slots.
Can pull the card to see if there's anything blocking airflow or the heatsink, and see if the heatsink mounting bracket is broken (happens sometimes)
BornJames
