vPC N3K connect with VSS on 6500
p
Can we configure vPC on N3K connect with VSS on 6500 ?
6 Replies 6
Can we configure Two Nexus 3000 vPC etherchannel with Two Catalyst 6500 VSS
No problem. This will works.
Do you have an example or diagram of configuration ?
Have N3K Model which support 10G 24Ports ?
Does we need two 10G for vPC Peer link right ?
I don't think it's a requirement but it would not make sense to not use 10g as the rest of the links are also 10g and traffic will traverse these links potentially so you would not want to have a bottleneck.
This is the vPC topology.
S3 = 6500
You can use this guide for configuration.
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-5000-series-switches/configuration_guide_c07-543563.html
