VPC showing consistency check not performed in ACI new leaf
I connected new two leafs 301,302 and configured vpc but when checking few commands like show vpc extended I can see consistency check not performed in one of the leaf (leaf 304) but not in leaf 303.
i want to know why this error is appearing and how can i resolve this issue.
details:-
-no endpoints  connected as of now on any of the new leaf ports yet.
Model-cisco N9K-C9336C-FX2
System version: 14.2(5n)
Apic ver:-4.2(5n)
leaf303# show vpc extended
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 10
Peer status : peer adjacency formed ok
vPC keep-alive status : Disabled
Configuration consistency status : success
Per-vlan consistency status : success
Type-2 consistency status : success
vPC role : primary
Number of vPCs configured : 7
Peer Gateway : Disabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Enabled
Auto-recovery status : Enabled (timeout = 200 seconds)
Delay-restore status : Enabled (timeout = 120 seconds)
Delay-restore SVI status : Enabled (timeout = 0 seconds)
Operational Layer3 Peer : Disabled
vPC Peer-link status
id Port Status Active vlans
1 up -
vPC status
id Port Status Consistency Reason Active vlans Bndl Grp Name
1 Po7 down* success success Switch303-304_P
rofile_PolGrp_i
nt21_23
2 Po6 down* success success Switch303-304_P
rofile_PolGrp_i
nt15
3 Po2 down* success success Switch303-304_P
rofile_PolGrp_i
nt25_27
343 Po4 down* success success Switch303-304_P
rofile_PolGrp_i
nt11
684 Po5 down* success success Switch303-304_P
rofile_PolGrp_i
nt17
685 Po3 down* success success Switch303-304_P
rofile_PolGrp_i
nt29_31
686 Po1 down* success success Switch303-304_P
rofile_PolGrp_i
nt13
leaf304# show vpc extended
Legend:
vPC domain id : 10
vPC role : secondary
1 up -
vPC status
1 Po4 down* Not Consistency Switch303-304_P
Applicable Check Not rofile_PolGrp_i
Performed nt21_23
2 Po7 down* Not Consistency Switch303-304_P
Performed nt15
3 Po1 down* Not Consistency Switch303-304_P
Performed nt25_27
343 Po2 down* Not Consistency Switch303-304_P
Performed nt11
684 Po6 down* Not Consistency Switch303-304_P
Performed nt17
685 Po3 down* Not Consistency Switch303-304_P
Performed nt29_31
686 Po5 down* Not Consistency Switch303-304_P
Performed nt13
leaf304#
Sergiu.Daniluk
The output you are seeing is expected because the interfaces (vPC) is down. Once the interfaces and vPC will come up the consistency check will be performed.
Stay safe,
Sergiu
