vPC type-1 configuration incompatible - STP error
CiscoBrownBelt
Level 6
Level 6
Joined a pair of 92K switches in a VPC domain. I receive the following below. Anyone know what may be wrong as I checked both switches and everything looks the same?
Configuration inconsistency reason: vPC type-1 configuration incompatible - STP
vPC domain id : 10
Peer status : peer adjacency formed ok
vPC keep-alive status : peer is alive
Configuration consistency status : failed
Per-vlan consistency status : success
global port type inconsistent
Type-2 inconsistency reason : Consistency Check Not Performed
vPC role : secondary
Number of vPCs configured : 0
Peer Gateway : Enabled
Dual-active excluded VLANs : 252
Graceful Consistency Check : Enabled
Auto-recovery status : Enabled, timer is off.(timeout = 360s)
Delay-restore status : Timer is off.(timeout = 150s)
Delay-restore SVI status : Timer is off.(timeout = 10s)
Operational Layer3 Peer-router : Disabled
So I notice on show consistency vpc global... I got the following on one switch but I don't see what is different between them to change them both to normal. ANy help??
STP Port Type, Edge 1 Network, Enabled, Normal, Disabled,
Name Type Local Value Peer Value
STP MST Simulate PVST 1 Enabled Enabled
BPDUFilter, Edge BPDUGuard Disabled Disabled
STP MST Region Name 1 "" ""
STP Disabled 1 None None
STP Mode 1 Rapid-PVST Rapid-PVST
STP Bridge Assurance 1 Enabled Enabled
STP Loopguard 1 Disabled Disabled
STP MST Region Instance to 1
nazimkha
Looks like one of the vPC legs you have a port configured as port type network and edge.
make sure the spanning-tree port type is matching for all vPC interfaces
nazimkha
Yes that was it thanks!
Hello guys,
I have the same issue please. somone can push me on the good way
Check all your interfaces that are part of the vPC and make sure they are the same (spanning-tree port type, etc.)
