10-14-2023 01:47 AM - edited 10-14-2023 01:49 AM
Hi All
With respect to integration of Cisco ISE ,Duo and GSuite. I integrate cisco ise and duo via generic saml application and i added duo info in saml id provider of ise. I configured sso in duo with gsuite. I am unable to see gmail primary authentication here, rather duo prompt directly appear if i do portal test settings in ISE. The error displayed while trying the output is
Error: IdP-initiated SAML Responses are not supported
Error Trace ID: 4043ac5f7945e098063a1f55
Any suggestion to change the integration steps or the missing leg of this integration flow or any resources to check the flow. I appreciate that.
Cheers.
Santhosh
Solved! Go to Solution.
10-15-2023 09:49 PM - edited 10-16-2023 12:14 AM
I resolved with my team.
