Deployment Strategy
Browse deployment advice, strategies and issues our community has identified and resolved.
Hello,We will be using GPOs for the configuration of the DUO settings, but NOT using GPOs for the deployment of the DUO Windows Logon software. We will use our own tools. I have not been able to find an answer to the following....1. If I am using GPO...
yoyoma by • Community Member
  • 1298 Views
  • 2 replies
I want to enable DUO PROXY in the HA mode.How should I do this correctly?I've set up a second machine identical to the first, and my "cloud" and "sso" security settings are the same. How should this be displayed in the "Authentication Proxy Dashboard...
piter1789 by • Frequent Visitor
  • 1805 Views
  • 4 replies
I have Duo MFA setup on Ubuntu servers.  I have Verified Push configured in the policy.  All is working fine and I can successfully SSH into the servers and use Verified Push.  However, when I try logging into a server via WinSCP, I am not given the ...
Has anyone created a script that can collect ALL the settings for an account (user and admin) into a file that can be used to duplicate the account settings for a new account? And is there a script that can use that output to copy those settings into...
Oldtrekky by • Level 1
  • 1263 Views
  • 1 replies
Hi, I have Anyconnect on Cisco FTD. It is integrated with Microsoft AD via LDAP and i do LDAP attribute mapping based on AD group and FTD policy so different user have different privileges. I need to setup to this user 2FA with DUO so i installed Duo...
mdzaf by • Level 3
  • 2183 Views
  • 5 replies
Hi,I have a customer who requires protecting 2 applications: RDP for windows terminal server, and Azure AD (in order to protect user's maibox and office apps).His environment includes an on-prem AD, synced to AAD.Both setups are already up and runnin...
yuvalg by • Community Member
  • 1073 Views
  • 1 replies
