DevNet Data Center
Share ideas about how to use data center developer tools to help manage virtual servers, deployments and more.
Activity in DevNet Data Center
Nexus 56128 CFS lock
cisco Nexus 56128P Chassissystem: version 7.3(7)N1(1)5K# sconfigure sync ; switch-profile pair501-502Enter configuration commands, one per line. End with CNTL/Z.Resyncing db before starting Switch-profile.Re-synchronization of switch-profile db takes...
Resolved! MOVED TO OTHER BOARD - Nexus 7K migration to Nexus 9K
EDIT: This post has been re-posted in the DataCenter forum. Any replies can please be made over there. (I thought that's where I was when I made this post. Apologies to all. If any mods see this, they can please delete this post here.) Hello all,We h...
vv0bbLeS_0-1787753418804.png vv0bbLeS_1-1787753842911.png vv0bbLeS_2-1787754068914.png
vv0bbLeS by • Level 7
  • 1023 Views
  • 4 replies
Nexus 3548P-XL: BIOSINFO Checksum Error Persists in L2 Mode
Hello, The following log message is occurring on a Cisco Nexus 3548P-XL (N3K-C3548P-XL) switch: %KERN-3-SYSTEM_MSG: biosinfo checksum failed expected ff Got c - kernel We referred to the Cisco TAC documentation related to CSCve63984 and performed the...
hsjung by • Community Member
  • 361 Views
  • 0 replies
UCS Cisco C240 M5 DIMM
I've tried multiple DIMMs , and multiple configurations, but anytime I get to this K1 slot I get an error.I'm assuming the slot is bad. Any known issues I should be aware of before I scrap this thing for parts?It's been an absolute nightmare. The fir...
Unable to access APIC via HTTPS — certificate error
I am connected to the DevNet Sandbox VPN and can reach the APIC at 10.10.20.14.Direct HTTPS access was successfully tested using:curl.exe -vk https://10.10.20.14The APIC responds successfully with:HTTP/1.1 200 OKServer: Cisco APICI also tested:curl.e...
Catalyst Center (DNAC) PnP API: Cannot Set Stack Member Numbering
Hi @All,Catalyst Center version: 3.1.6I am working on a NetBox-based Zero-Touch Provisioning solution for Cisco Catalyst switches using Catalyst Center PnP.The PnP workflow and CLI template deployment work correctly. However, I cannot define the requ...
Bleblas2 by • Community Member
  • 433 Views
  • 0 replies
cisco.dcnm.dcnm_vrf error: 'str' object has no attribute 'get'
When using the ansible cisco.dcnm.dcnm_vrf module I get this error:[NDFC_VRF_ActionPlugin] ERROR: AttributeError in Operation: fabric_discovery: 'str' object has no attribute 'get' Task failed: {'failed': True, 'msg': "'str' object has no attribute '...
ckudari by • Community Member
  • 613 Views
  • 0 replies
Poap with n9kv and Nexus Dashboard
I'm trying to set up a CML lab for inband eVPN poap deployment from Nexus Dashboard.So far it's going well but I am running into the boot issue and I'm not sure how to fix it (or if it's even possible).I would like the end result to be:- A user wipes...
