Help with AXL and PHP - SOAP Fault Exception
Daniel Ball
<?php
$host="10.10.20.1";
$username="administrator";
$password="password";
$context = stream_context_create(array('ssl'=>array('allow_self_signed'=>true)));
$client = new SoapClient("AXLAPI.wsdl",
    array('trace'=>true,
'exceptions'=>true,
'location'=>"https://".$host.":8443/axl",
'login'=>$username,
'password'=>$password,
<html>
<head>
<title>PHP Test</title>
</head>
<body>
<?php
$response = $client->getUser(array("userid"=>"user01"));
echo("First Name: ".$response->return->user->firstName)."<br>";
echo("Last Name: ".$response->return->user->lastName);
</body>
</html>
Using the above code, I keep getting an error message -> "SoapFault: SoapFault exception: [HTTP] Could not connect to host..."
- I'm using the CUCM in DevNet. I'm connecting to it with anyconnect and the login credentials that are emailed to me when I reserve the CUCM.
- I'm sure the WSDL file is in the same directory as my main php file.
- I can successfully pull up a web page (Chrome), type in https://10.10.20.1/8443/axl and get a message that axl is working.
- Not sure if it matters, but I'm also using XAMPP to serve my php pages.
I've read elsewhere that other people have been able to solve this problem by using the hostname instead of an IP address. So, for $host, I've also tried, q-cucm-pub.abc.inc, q-cucm.cisco.com, and any other permutation I can think of in place of the ip address, but I get the same results.
SOAP has always been a mystery to me. Many thanks to anyone who might be able to help.
0 Replies 0
