How to use ansible ios_acl module to merge a list of ACL's
DAVID
Level 3
Level 3
I have an extended access list and for simplicity sake I will say it is lines 1 to 10.  I want to add lines 11 to 15 to the existing extended ACL using the ios_acl module for Ansible.  I need to be able to loop through each acl I have in the playbook so that each rule will be appended to the end of the list of ACLs. Here is my playbook but since I am still learning, I am at a loss as to the simplest way to accomplish my task.
- name: Merge Access Lists
  hosts: Router
  gather_facts: False
  connection: network_cli
  vars:
    acl_name: pos-to-wan
    acl_rules:
      - name: 911
        action: permit
        source: any
        destination: 198.22.203.230
        port_protocol: 443
      - name: 912
        action: permit
        source: any
        destination: 209.236.103.70
        port_protocol: 443
      - name: 913
        action: permit
        source: any
        destination:  198.22.206.247
        port_protocol: 22
      - name: 914
        action: permit
        source: any
        port_protocol: 990
      - name: 915
        action: permit
        source: any
        range: 64000 645000
      - name: 916
        action: permit
        source: any
        destination: 209.236.103.119
        port_protocol: 22
      - name: 917
        action: permit
        source: any
        port_protocol: 990
      - name: 918
        action: permit
        source: any
        range: 64000 645000
  tasks:
    - name: Merge Access List Rules
      cisco.ios.ios_acls:
        config:
        name: "{{ acl_name }}"
        rules:
          - "{{ item }}"
        state: merged
      loop: "{{ acl_rules }}"
    - name: Resequence  Access List
      ios_config:
        lines: ip access-list resequence pos-to-wan 10 10
    - name: Save Running config
      ios_config:
        save_when: modified
Marcel Zehnder
Hi David
If you want to add addional entries to the ACL I think you can do it without a loop, just align the dicts in your "acl_rules" variable to the schema of the dict used in the Ansible module (https://docs.ansible.com/ansible/latest/collections/cisco/ios/ios_acls_module.html):
  hosts: Router
  gather_facts: false
  vars:
    acl_rules:
      - sequence: 911
        grant: permit
        source:
          any: true
        destination:
          host: 198.22.203.230
          port_protocol:
            eq: 443
        protocol: tcp
      - sequence: 912
        grant: permit
        source:
          any: true
        destination:
          host: 209.236.103.70
          port_protocol:
            eq: 443
        protocol: tcp
      - sequence: 913
        grant: permit
        source:
          any: true
        destination:
          host: 198.22.206.247
          port_protocol:
            eq: 22
        protocol: tcp
  tasks:
      cisco.ios.ios_acls:
        config:
          - afi: ipv4
            acls:
              - name: "{{ acl_name }}"
                acl_type: extended
                aces: "{{ acl_rules }}"
Marcel
Marcel Zehnder
Hi David
  hosts: Router
  gather_facts: false
  vars:
    acl_rules:
      - sequence: 911
        grant: permit
        source:
          any: true
        destination:
          port_protocol:
            eq: 443
        protocol: tcp
      - sequence: 912
        grant: permit
        source:
          any: true
        destination:
          port_protocol:
            eq: 443
        protocol: tcp
      - sequence: 913
        grant: permit
        source:
          any: true
        destination:
          port_protocol:
            eq: 22
        protocol: tcp
  tasks:
      cisco.ios.ios_acls:
        config:
          - afi: ipv4
            acls:
                acl_type: extended
Marcel
Thanks for all your help.  With a few changes, I was able to accomplish the task that I was after.  Here is my revised file:
gather_facts: False
  vars:
    acl_rules:
      - sequence: 911
        grant: permit
        protocol: tcp
        source:
          any: true
        destination:
          host: 198.22.206.230
          port_protocol:
            eq: 443
      - sequence: 912
        grant: permit
        protocol: tcp
        source:
          any: true
        destination:
          port_protocol:
            eq: 443
      - sequence: 913
        grant: permit
        protocol: tcp
        source:
          any: true
        destination:
          port_protocol:
            eq: 22
      - sequence: 914
        grant: permit
        protocol: tcp
        source:
          any: true
        destination:
          port_protocol:
            eq: 990
      - sequence: 915
        grant: permit
        protocol: tcp
        source:
          any: true
        destination:
          port_protocol:
            range:
              start: 64000
              end: 64500
      - sequence: 916
        grant: permit
        protocol: tcp
        source:
          any: true
        destination:
          host: 209.236.103.119
          port_protocol:
            eq: 22
      - sequence: 917
        grant: permit
        protocol: tcp
        source:
          any: true
        destination:
          port_protocol:
            eq: 990
      - sequence: 918
        grant: permit
        protocol: tcp
        source:
          any: true
        destination:
          port_protocol:
            range:
              start: 64000
              end: 64500
  tasks:
      cisco.ios.ios_acls:
        config:
          - afi: ipv4
            acls:
                acl_type: extended
      ios_config:
      ios_config:
        save_when: modified
This is not idempotent (always reports changed status) for me, was it for you guys?
