I want the Beacon LED to light up at boot up.
kakishik
As the title says,
Could you please let me know if it is possible to make the Beacon Blue LED light up at startup?
I would especially like to know how to do this for Catalyst9000 and 4500.
I dont known but you can try beacon command and knor to led specific port when reboot.
Leo Laohoo
Can be done using EEM.
Not sure if 4500 even has a blue light.
Reach out to @Joe Clarke.
Ruben Cocheno
@kakishik
Has this been resolved? Do you still need help?
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
