Images for GNS3
miriamc
I am currently learning GNS3 and I am aware that I need to obtain the relevant images/licenses. Is anyone aware of what I need to purchase exactly? Is it ' Cisco Modeling Labs - Personal'
No, you don't necessarily need to purchase Cisco Modeling Labs (CML) Personal if you're using GNS3, Note however, that Cisco images are copyrighted and available through a Cisco service contract. It is not suggest or encourage the use of unauthorized sources/websites to download them, Cisco images from here https://software.cisco.com/
The Cisco VM images that are provided for download with Cisco Modeling Labs or as part of the CML refplat ISO file are only licensed for use within Cisco Modeling Labs. Downloading these VM images and using them outside Cisco Modeling Labs without a proper license is prohibited.
 Reference: https://developer.cisco.com/docs/modeling-labs/#!vm-images-for-cml-labs
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Ruben Cocheno
@miriamc
Just go to the learning store from Cisco and acquire a CML personal license
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Martin L
 there is GNS3 forum; any info regarding imaging over there? I would check first if CML images will work in gns
Regards, ML
**Please Rate All Helpful Responses **
