TCL script || yes/no
sebasttee
Frequent Visitor
Frequent Visitor
I need some help to do a script to accept "Yes" from CLI
I want to do TCL Script to put this command: vrf upgrade-cli multi-af-mode common-policies vrf XXX
If i insert this command on CLI, it´ll give me:
ROUTER(config)#vrf upgrade-cli multi-af-mode common-policies vrf NAC
You are about to upgrade to the multi-AF VRF syntax commands.
You will lose any IPv6 addresses configured on interfaces
belonging to upgraded VRFs.
Are you sure ? [yes]:
My script will be something like this:
tclsh
ios_config "vrf upgrade-cli multi-af-mode common-policies vrf XXX"
but then i don´t know to accept the "yes".
Can someone give a suggest?
good to know it was solved, the document have that command syntax.
BB
balaji.bandi
Look at this thread, you need to use regex to parse the output and take action based on output.
https://community.cisco.com/t5/network-management/tcl-cli-read-pattern/td-p/2261228
BB
I have already looked to that thread. I'm not familiarize with this type of language. I was look for something easier.
I have found a solution.
tclsh
foreach VRF {
aaa
bbb
} { puts "[ ios_config "vrf upgrade-cli multi-af-mode common-policies vrf $VRF" ]" }
yes
yes
tclquit
BB
