Catalyst Center always on lab
malcomx
is this the same as the Catalyst Center lab listed?
Torbjørn
The always-on lab is always on and available without having to use a VPN. It differs from the other Catalyst Center lab in that it is not a reservable/bookable resource. Connection info is listed under "instructions" and you can use it's API like you would any other DNA center/Catalyst Center.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Yes, devenet offers two variations in their sandbox, the main difference being here the always on version of this sandbox is read only, if you are testing the API's, you will only be able to use GET functions.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Ruben Cocheno
@malcomx
yes, however this gives you a touch and feel without reservation.
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
