Cisco Firpower 4110 blade w/ ASA Devices not accessable
james420
Within the Firepower 4110 with single asa sandbox.  Neither the Chassis or the ASA is available via either ssh or https.  the only device I was able to connect to was the Server VM.  Please take a look, need to get an ASA config tested.  I found a post earlier that had the same issue and it required Devnet to fix.
Thanks!
James,
Can you try spinning up the Firepower lab again and verifying you can get access to the Blade (10.10.20.30). Also, it seems that ssh access to the ASA virtual device is not working and we are looking at that. In the meantime, you can console to teh asa through the firepower blade as follows:
ssh admin@10.10.20.30
F!repower
connect module 1 console
username:     admin
Password:     cisco
en
no enable password configured. just hit enter.
Joe
5 Replies 5
james420
Anyone have any suggestions?  I've tried ending the sandbox and reserving a new one, same result. It appears that the sandbox image is broken from the start.  Not a very helpful environment to test the 4110 if it doesn't provide access to the 4110 or the ASA image that's running on it.
James,
Apologies for the delay. We will be checking on this issue later today. I can provide an update to you in the afternoon (GMT).
Joe Kearns
James,
I need to end your reservation to troubleshoot the issue. You will be able to rebook the session once its back up.
We will let you know.
Joe
James,
F!repower
username:     admin
Password:     cisco
en
Joe
James,
Going to close this case. We can reactivate if you see any other issues.
Joe
