Cisco SD-WAN 19.2 Always On - vEdge Devices missing
mrowan
Something has broken with the SD-WAN Always on the environment. The only devices left are the vManage, vBond and vSmart, all the Edge devices are no longer present.
I just saw this also, investing the issue with our team. Please standby.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
I see the CSR devices are back but the vEdge device in site3 is still missing. Any update on when this is likely to be resolved?
ENG team continues to work on the issue, which was due to malicious use.
I would suggest using the reserved sandbox and check back after the planned maintenance this weekend. https://devnetsandbox.cisco.com/RM/Diagram/Index/c9679e49-6751-4f43-9bb4-9d7ee162b069?diagramType=Topology
Hope this helps.
