Connecting Using A Hardware VPN
Terence Bell
I wanted to know how I go about receiving a test Cisco router so I can have Hardware VPN access to the labs. Any information would be helpful.
Hello Terence, i do not believe this method is supported. Using the Any Connect VPN client is the recommended way.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
