Connection to IOS XE on Catalyst Always-On
nazgul99.01
Trying to connect  IOS XE on Catalyst Always-On by ssh and get response - connection reset by peer. On Quick Access show status - SSH Connection Failed. Can you help to resolve a problem?
7 Replies 7
reset by peer
can you check the session timeout and idle timeout
liviu.gheorghe
Hello @nazgul99.01 ,
can you do a debug ip ssh on the IOS XE box?
Regards, LG
*** Please Rate All Helpful Responses ***
Typically happen when another uses has made changes and locks others out of the device. Maybe wait a little while for the device to reset.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Ruben Cocheno
@nazgul99.01
Someone just lock out the setup, wait for 4 to 8 hours before try again.
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
ansiblenovice
This has been going for at least 24hrs since I've noticed.
Disregard, the URL has been changed to: devnetsandboxiosxe.cisco.com
NM, that still resolves to the same IP, which still has the same issue:
ubuntu@touching-blesbok:~$ ssh admin@devnetsandboxiosxe.cisco.com
kex_exchange_identification: read: Connection reset by peer
Connection reset by 131.226.217.181 port 22
